'After Each New Day' email not being sent. **solved**
YorkshireHam
Post by YorkshireHam »
I have a service event setup to send an email after each new day.
This has been working for many months but suddenly stopped being automatically sent. I can send it by clicking the test button and that works OK. I setup another event with the same service delivery (after each new day) and that will only work by clicking the test button also. An event set up for after every new month is still working and has worked OK today.
I have done a reboot (get newest version on reboot selected) and this has made no difference.
Any ideas please.
Re: 'After Each New Day' email not being sent
I have a feeling this has something to do with there being no data availability when triggered as I have seen a similar issue over the past 2 nights related to a similar context but with a "Before each new day" export for the current day.
This was when running FW 5.1 Build 3844, Apr 27 as updated on 29/4/21 which resulted in no export for the night of the 29th or 30th. This didn't appear to be an issue with previous FW 5.1 Build 3819 April 10
Have rolled things back to FW 5.0 to test tonight.
And yes similar with manual test works fine in regard local export and triggered Export.
YorkshireHam
I have rebooted to SW v5.0, Jan 1, 2021 build 14213 and now both of my 'after each new day' service events have been sent correctly.
Does that suggest there is a bug in SW v5.1?
Similar here with FW 5.0, last 2 days exported as expected.
Please try latest realease, I fixed a bug.
Updated one unit to 5.1 May 2, 2021 build 14406 which exported ok last night.
Will update a couple more units and check further tomorrow.
YorkshireHam
Rebooted to 5.1 (May 2 2021 build 14406) and emails now being sent correctly.
Thank you.
Reboot to Meteobridge 5.1 (May 3 2021, build 3864), the NanoSD forgets my configured station 1 (Airlink). I had to set it up again in the metoebridge.
MBPro with 5.1 (May 2 2021, build 14406) FW 1.4 now working as expected
NanoSD with 5.1 (May 3 2021, build 3864) FW 1.3 now working as expected
