After 5 years, Vantage Vue, MeteoStick and Meteobridge have stopped working and don't know why
Posted: Tue May 11, 2021 12:35 am
by kdrotar
Hello.
I hope you are well and hopefully you can help.
For 5+ years I have had a Davis 6357 connected to a MeteoStick 1.0 and TP-Link Meteobridge (small white box). It has worked flawlessly until a few days ago and now it isn’t showing any raw data or uploading to Wunderground like it used to.
The Davis unit still seems to be sending a signal (blinking green light).
The MeteoStick blinks green.
However, the MeteoBridge configuration software looks different than it used to, and I may not be configuring it correctly.
For the “Primary Station” do I choose “Vantage” or “MeteoStick Vantage”?
Has something changed with recent firmware/software updates?
Any help would be appreciated. This has worked wonderfully for years.
Thank you!
Meteobridge info 5-10-21.JPG (65.68 KiB) Viewed 1797 times
Current MeteoBridge lights, not fast blinking...
Current Meteobridge Lights.JPG (73 KiB) Viewed 1797 times
Re: After 5 years, Vantage Vue, MeteoStick and Meteobridge have stopped working and don't know why
Posted: Tue May 11, 2021 12:53 am
by BigAlT
Since you now have the most recent version of the Meteobridge Software dated May 6 and that seems to be when you started having problems I suggest reverting to an earlier version of the Meteobridge software that you know was working and see if that solves the issue. If so you know there’s a bug in the most current release as it pertains to your setup.
Posted: Tue May 11, 2021 11:18 am
by wvdkuil
kdrotar wrote: Tue May 11, 2021 12:35 am . . .
You should choose "Meteostick Vantage" as that is what you use.
The other choice is used for Davis VP stations with a logger .
=== Question: When did it stopped working?
=> Did it work with the old configuration until the last moment?
F.i. you installed the new version for another reason.
Probably a configuration problem, either with selecting the station or a WiFi problem
=> Or did it stopped working with the old version?
F.i. To try to solve the problem you installed the newest update.
That could mean that after 5 years the device failed
Posted: Tue May 11, 2021 4:10 pm
by kdrotar
Thank you for your responses! I did revert back to 5.0, but then also noticed that setting up the station is now a two-part step with the newer UI in Meteobridge (there used to be one long page with various checkmarks and boxes to fill).
It seems to be working, but since I didn't check the software change by itself, I'm not certain if it was that or my Station configuration. In any case, thank you for replying. I really appreciate it. Here is what my Station configuration now looks like:
now it's working!
now it's working!
Meteobridge info 5-10-21 (started working after reconfig).JPG (58.21 KiB) Viewed 1765 times
