Hi all, I'm running 2 Meteobridge Pro Red and Weather34. It's working perfectly. Extra info is working fine for except 2. The temperature en Dewpoint tile. Both are empty. No idea where to look to solve the issue. Grateful for any help ??
Modify message
Isaac
https://www.meteo3131.nl/Weather34/
Extra info graph info missing since last weather34 upgrade
ikorpershoek
- Fresh Boarder
Re: Extra info graph info missing since last weather34 upgrade
Hello
looks like something got messed up there in those two files .
if you pm me your email address I can send you a weather34charts update file which you can run through the simple updater screen. it will just update all files in the weather34charts folder except csv files/folders.so you won't lose any data stored.
Brian
Brian
good morning ill will release an update for this sometime today as I have received same issue from others . brian
please go to thread viewtopic.php?f=56&t=15243&p=39559#p39559ikorpershoek wrote: Thu May 13, 2021 1:08 pm Hi all, I'm running 2 Meteobridge Pro Red and Weather34. It's working perfectly. Extra info is working fine for except 2. The temperature en Dewpoint tile. Both are empty. No idea where to look to solve the issue. Grateful for any help ??
Modify message
Isaac
the update 14th May just released should fix the problem.
Brian
