I attempted to replace my camera with a Zymodo ZP-IBH23W. Edited the old config trying to connect the new cam. Now all the drop down options i.e. Primary Station, Cam, Settings, Mapping, all return a Bad Gateway -The process did not produce any response.
Any guidance is appreciated.
TL-MR3020V3 (no USB hub) -ethernet connected
RAM: 60592 kB total, 18992 kB free (68% used)
SW Version: Meteobridge 5.1 (May 6 2021, build 3867), FW 1.3
Uptime: 15 hours, 28 minutes Buffer: 2 items (0%)
PWS Ecowitt GW-1000
thx much!
Bad Gateway The process did not produce any response. **solved**
