meteobridge-rpi3-v1.3.bin
Scobey
Post by Scobey »
I have an RPI 3B+ and am using a compliant SD card. When I burn the bin and run I get the following and the script stops.
323.8589521 done /home/setup.sh
GRRRRR! What’s up with this?
BigAlT
Re: meteobridge-rpi3-v1.3.bin
Post by BigAlT »
When first booting up your RPi after inserting the freshly burned micro SD card with the Meteobridge disk image does the red LED on your RPi behave as it should ?.
Having copied the disk image to the card it just needs to insert the card into the Raspberry Pi, connect it with an Ethernet cable to your LAN and to power it up. Your card is flashed fine when the red LED starts blinking slowly and then changes to fast blinking after a while. When the red LED reaches steady on, your Meteobridge has successfully reached out to the Internet, has loaded the application stack and is ready to go. When you don't see the blink -> fast blink sequence, your low level copying of the Meteobridge image to your microSD card has failed.
Scobey wrote: Fri May 28, 2021 8:45 am I have an RPI 3B+ and am using a compliant SD card. When I burn the bin and run I get the following and the script stops.
Works as designed. Did you login with your browser?
