Meteobridge reporting live data from Davis Leaf/Soil station when sensors unplugged
jclark50
Post by jclark50 »
When unplugging one or all of my soil temperature probes connected to a Davis soil/leaf station, Meteobridge still shows that data is being sent when looking under “Raw Sensor Data”. The ‘temperature’ it is reporting is simply the last temperature that was measured before the probe was unplugged.
For sensors like air temperature that are connected to the main Vantage Pro 2 ISS, Meteobridge correctly shows that no recent data has come in when one of those is unplugged (red number under “Signal” showing the duration the sensor has been unplugged).
Is there a reason this behavior of correctly marking data as old doesn’t worth with the soil station? I am using an Envoy 8x if that makes a difference and my Meteobridge is running the latest firmware (flashed on a TL-MR3020). I seem to recall this behavior working before I switched to an Envoy 8x, so I’m wondering if there’s a possible solution?
Re: Meteobridge reporting live data from Davis Leaf/Soil station when sensors unplugged
The EOL Envoy8x is very rare out there and a very complicated device. I am reluctant to touch the code for it because I can't test here and my fear is that I break something. Therefore, I prefer to keep as is. Looks like you can cope with the issue (no data missing or alike).
