Meteobridge summarized on a page
General information and solutions to the most prominent issues
As I am often expected to explain what Meteobridge is about, I created a mind map about the aspects that make up Meteobridge. If you find yourself in a situation to explain or if you like to check if you have seen every aspect, this map might help.
https://admin.meteobridge.com/files/Met ... a-page.pdf
