Connection fail to allow weatherlink.com updates(HELP)
Eguraldia
Post by Eguraldia »
Hello everyone,my firts message here..I need some help
please find attached some pictures...
I have a problem since this morning
Weather station Davis Vantage Pro IP data logger and send information for a long time by meteobrigde tp linkl-mr3020 V10 F
"These stations can be equipped with an IP-based Logger called WLIP. If you have one of these, please select WLIP operation (and how often Meteobridge should pause to allow upload to Davis Weatherlink services in parallel to Meteobridge operation) and enter IP and port (separated by a colon) in the input field next to the selection box (example: "192.168.1.222:10001"). This will tell Meteobridge to connect this station not via USB but via your LAN/WLAN (in the example on IP 192.168.1.222 at port 10001). When you don't specify a port, the WLIP default port (22222) is used."
Well,I have the settings WL upload every 1 minute to weatherlink.com(the bulletin) but its not working at all...If I turn off meteobrigde..working but with meteobrigde non
The rest everything was ok..
The last thing I did..turn off meteobrigde and now I try with another software(weatherdisplay)released conection everyminute to allow weatherlink.com updates and with this software everything its ok.... :roll:
Someone out there have the same issue..need some help
ghasdorff
Re: Connection fail to allow weatherlink.com updates(HELP)
Post by ghasdorff »
Did your Davis logger stop reporting to WeatherLink when the meteobridge updated to version 5.2?
I had two stations with that problem this week, both stopped reporting to WeatherLink when meteobridge updated to version 5.2. At some other stations with meteobridge using lower versions the Davis connection to WeatherLink is still working.
ghasdorff
Post by ghasdorff »
This is a new problem with meteobridge 5.2.
Here is a temporary workaround that worked for me. On the two stations where I saw the same problem you described I set the meteobridge to use version 5.1 software instead of the latest, like this:
  • "System" tab
    "Administration" subtab
    "Version Control" box, pull down the list and select "stick to version 5.1"
    click "Save and Apply" at the bottom, wait for the message
    click "Reboot" at the bottom, wait a few minutes for the meteobridge to load version 5.1 and restart
The WeatherLink data comes back right away by itself after changing the meteobridge from 5.2 to 5.1
Hopefully the issue with 5.2 will be fixed by the next version.
