Bad sensor data
Snapper
Bad sensor data
Post by Snapper »
Hi
Seeing this in my logs for a MB Pro Red:
logger (21.09.2021 19:50:47): Bad th0(0) sensor data, "dew point x10" (-752) out of range [-700:1500]
logger (24.09.2021 12:32:37): message above repeats 19264 times.
I’m guessing its because my transmitters are set up:
Ch0: Wind, Solar & UV. (MBP type ISS)
Ch1: Temp & Humidity only. (MBP type Temp & Humidity station)
Ch2: Rain only. (MBP type Rain Station)
So any temp/hum data being sent from ISS 0 isn’t valid as the temp/hum sensor isn’t present…
Can these be suppressed?
Snapper
Re: Bad sensor data
Post by Snapper »
@Boris - are these messages causing a problem & need suppression?
Re: Bad sensor data
Situation is caused as you tell Meteobridge it is an ISS (in order to have wind, solar and uv data collected), but in the end temperature - as expected by an ISS - is missing.
However, I don't see an issue. Filling up the logs is prevented by the repeat message detection.
