Problem upload via SFTP to Provider Deutsche Telekom
xray77
Post by xray77 »
Hello Forum,
Does anyone else with a MeteoBridge Nano SD have problems uploading content via SFTP to their web space at "Deutsche Telekom"? Since 11 October 11 am, uploading is no longer possible here, the access data have not been changed. The SFTP upload via a manually controlled FTP-program under Windows 10 works without any issue with the same access data.
All other services of the MeteoBridge including the upload of data via API (weather networks) work perfectly, only the upload via SFTP does not work anymore. The latest firmware of the MeteoBridge from 10 October has been installed, no change. If anyone else has this problem, I would be grateful for info or even a solution!
The problem does not occur with my own wards, an acquaintance is affected by it, for whom I have opened this post.
Best regards
Mike
xray77
Problem MeteoBridge Nano SD no upload possible via SFTP still persist...
Post by xray77 »
The problem described above still exists: The Meteobridge Nano SD can't longer upload data via the SFTP protocol. Other (Windows) SFTP programs, however, work perfectly with the same access data.
We have tested the Upload via SFTP with two different MeteoBridge Nano SD with actual Firmware, both devices are unable to upload via SFTP..
Boris: Has something perhaps gone wrong with one of the last firmware updates that prevents uploading via SFTP? Perhaps this is no longer possible in general?
Actually, more users in German-speaking countries who have German Telekom as their provider or who upload data via SFTP at all should be affected?
It would be great if someone with the same problem could get in touch, many thanks,
best regards
Mike
