RF and wifi cables replacement info
websign
Post by websign »
Good morning. I have a problem. My meteobridge has RF and WIFI reception problems. I opened the meteobridge case and saw that the cables that connect to the electronic boards from the external connector are twisted. Would it be possible to have the technical specifications of cables and connectors so that I can buy spare parts? Thanks so much
websign
Re: RF and wifi cables replacement info
Post by websign »
I found these:
RF: https://it.rs-online.com/web/p/cavi-av/7619881/
WIFI: https://it.rs-online.com/web/p/accessor ... o/7694185/
Are these cables correct? Can I order these?
Thank you :)
Yes, these are fine. Please note the WiFi and RF connectors have different gender (pin, no-pin).
Please make sure that the connectors are firmly screwed to avoid them rotating again and twisting the cables.
