evapotranspiration. **solved**
paul_1055
Post by paul_1055 »
With NanoSD and VantagePro the variable [sol0evo] is available,
Is it possible to make the variable available for a meteobridge on an rpi?
Greetings Torsten
Re: evapotranspiration
paul_1055 wrote: Sun Dec 05, 2021 8:19 am With NanoSD and VantagePro the variable [sol0evo] is available,
Greetings Torsten
The value is only available when a Davis Vantage console is attached as it is a calculated value inside the console itself.
Regards,
paul_1055
Post by paul_1055 »
Too bad, but thanks for the info
Greetings Torsten
