TP-Link TL-MR3020 constantly restarting every 1-1.5 minutes... **solved**
rmccullough
Post by rmccullough »
This started after I applied a new license key and rebooted.
All I can do is get into OpenWRT and poke around until it reboots.
Re: TP-Link TL-MR3020 constantly restarting every 1-1.5 minutes...
Is it stuck at fast blink mode? If so problem is that it cannot load the application stack from the internet.
Did you try factory reset via the "5 blink reset" as explained in the wiki (end of getting started section)?
rmccullough
Oops. Forgot to come back and say that it eventually sorted itself out at some point the same night. Don't remember what the light was doing. But that explains why the v3 version I just bought was stuck at the fast blinking step...
Gary
Re: TP-Link TL-MR3020 constantly restarting every 1-1.5 minutes... **solved**
Post by Gary »
In trying to figure out how to resolve the license, I found a post about reset my old 3020 device using the "5 blink method". Which I did, and it brought my old device back to life. Now that I already flashed my new one, I can't return it without restoring the firmware. as my old one is EOL for Meteobridge, I was able to migrate the license, so will go ahead and finish my setup.
Documenting all this so if anyone else has similar issues as mine can see how solved.
