edit template
Ger
edit template
Post by Ger »
I have a meteobridge pro. I want edit the display template (BIG-scroll-ISO.dsp).
Cannot find the address for editing this or another template. Please help
Re: edit template
It is located on the network share that Meteobridge provides to your PC. templates are in folder /data/templates.
Ger
Re: edit template
Post by Ger »
Thanks, but I think that meteobridge doesn't share anything on my PC.
Re: edit template
Ger wrote: Mon Jan 03, 2022 1:00 pm Thanks, but I think that meteobridge doesn't share anything on my PC.
The default Meteobridge Nano and Pro share this folder.
But latest version of windows-10 do not support the "old" SMB protocol which is used by most other systems
You have to swirtch SMBv1 on in your windows PC.
Similar answer from admin
viewtopic.php?f=57&t=13327
But it can be that SMB is not switched on in your Windows10 at all. Maybe these links can help:
https://www.windowscentral.com/how-acce ... windows-10
This topic, although it is for a Meteohub.
viewtopic.php?f=8&t=14633&p=31871&hilit ... dge#p31871
Ger
Re: edit template
Post by Ger »
Thanks Wim, I have now SMB activated. I cannot see a folder "Data" (no such file or directory) But i do see a folder "public" and in that folder "template.cgi". Unfortunately is that folder empty.
Re: edit template
Ger wrote: Mon Jan 03, 2022 7:15 pm Thanks Wim, I have now SMB activated. I cannot see a folder "Data" (no such file or directory) But i do see a folder "public" and in that folder "template.cgi". Unfortunately is that folder empty.
Using a MAC => nano
Windows10 => MB-raspberry
Windows10 => nano
They show the full list of folders
Did you access your Metebridge as guest ?
You should access it as user meteobridge with password meteobridge.
Ger
Re: edit template
Post by Ger »
Good Morning Wim, I have used theIPnr/nano and got No such file or directory, same with MB-raspberry
Re: edit template
Ger wrote: Tue Jan 04, 2022 12:23 pm Good Morning Wim, I have used theIPnr/nano and got No such file or directory, same with MB-raspberry
But did you use the logon meteobridge / meteobridge ?
If not you are visiting the Meteobridge without a userid/passw , you are only shown the files everybody is allowed to see.
Did you try to type the folder-name manually data\ ?
I am out of ideas as I use my Mac 99% of the time.
The 2 windows machines see the Meteobridge and allow me to browse the folders.
Ger
Re: edit template
Post by Ger »
Bedankt Wim, ik vergeet het maar.
