Duration of Import
Bart
Duration of Import
Post by Bart »
I can't find how long an import takes.
I want to import last year's data (Meteotemplate) into my new MB Pro. The Pro continues to report that the import has started. Because I saw the same message after 3 hours, I stopped that import. No data transferred.
Tried it with a 4 days. Again no other message than that it had started. But after 2 hours it turned out (after I stopped again) that those 4 days were transferred neatly. So now I don't know what the duration of the process.
In short:
Roughly how long (e.g. per day to be imported) does it take. - are other processes running in the meantime - what should be the message when the import is ready?
Bart
hymrog
Re: Duration of Import
Post by hymrog »
On the RPi you can see the start and finish of the upload on the log but you may need to refresh the page if I recall. Assuming it works the the same way on the Pro.
g
