New disk image for RPI 4B rev 1.5 models
It turned out the the newest batch of RPI 4B models with revision 1.5 need an updated boot section.
We just released a new disk image that takes care of this. The link to the disk image in "Preparing Hardware" section of the Meteobridge wiki has been updated accordingly.
Link: https://meteobridge.com/wiki/index.php/ ... croSD_card
Gyvate
Re: New disk image for RPI 4B rev 1.5 models
Post by Gyvate »
you can check you RPi 4B's hardware revision by connecting to the the RPi (e.g. via SSH) and enter the command
cat /proc/cpuinfo
Any Linux derivate will show the info like
:~# cat /proc/cpuinfo
processor       : 0
BogoMIPS        : 108.00
Features        : fp asimd evtstrm crc32 cpuid
CPU implementer : 0x41
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
processor       : 1
BogoMIPS        : 108.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
processor       : 2
BogoMIPS        : 108.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
processor       : 3
BogoMIPS        : 108.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
Hardware        : BCM2835
Revision        : b03114
Serial          : 100000000d9e1880
Model           : Raspberry Pi 4 Model B Rev 1.4
root@MeteoBridge:~#
the example is for a RPi4B 2 GB hardware Rev. 1.4
markhiseman
Post by markhiseman »
I am setting up Meteobridge on a new RPI 4B, but I can't get the WiFi to work. You say on the 'preparing hardware' page that "If you have trouble in making use of WiFi please try previous v1.3 disk image" ... but that doesn't boot, I guess because of the need for an updated boot section. Will you be updating the 1.3 disk image so we can get the WiFi working? Or is there a fix for the 1.4 disk image? Thanks. Mark.
bam
Post by bam »
Any chance that the Raspberry Pi 400 https://www.raspberrypi.com/products/raspberry-pi-400/ will be supported?
The Raspberry Pi 400 is extremely close to the 4B, mostly a few strings report different values for the machine type/ID.
Gyvate
Post by Gyvate »
bam wrote: Tue Sep 20, 2022 12:35 am Any chance that the Raspberry Pi 400 https://www.raspberrypi.com/products/raspberry-pi-400/ will be supported?
If you have RPi 400, did you try to start Meteobridge from an image, be it the v1.3 or v1.4 image and see what it gives ?
It might work :wink:
RPI400 is not really suited for Meteobridge as Meteobridge does not work with a local keyboard nor does support a local screen. Meteobridge is designed as a headless appliance for hardware that is dedicated to a single purpose: to run Meteobridge, nothing else. Therefore, we did not build an image for that. If one of the exiting RPI images do for RPIU400 I can't say.
Gyvate
Post by Gyvate »
it would show the whole openWRT startup sequence and related messages on the screen - something for an OS enthusiast but of little use for a Meteobridge user.
You can also see them when you connect a RPi4B during startup to a display.
Technically it could work, but it would be a waste of the resources like the monitor and the keyboard.
Would still be intersting to know if it works technically - the effort is just copying one of the images on a SDcard and trying to start the RPi 400 up with it.
If you happen to have a spare RPi 400 and have no other use of it, why not use it then for MB (if it works - tbd).
bam
Post by bam »
Gyvate wrote: Tue Sep 20, 2022 12:47 am
It did not work.
bam
Post by bam »
Gyvate wrote: Tue Sep 20, 2022 3:53 pm it would show the whole openWRT startup sequence and related messages on the screen - something for an OS enthusiast but of little use for a Meteobridge user.
Yeah, I was able to buy RPi 400 but not 4B. Out of stock issue for months now. :(
Gyvate
Post by Gyvate »
bam wrote: Wed Sep 21, 2022 10:28 pm Yeah, I was able to buy RPi 400 but not 4B. Out of stock issue for months now. :(
Not sure in which country you live ... I'm located in Germany and here you can get a RPi4B 2GB - for double the price it used to be before the COVID-19 pandemic though (e.g. 125 EUR now). Available. Delivered in two days.
bam
Post by bam »
Gyvate wrote: Wed Sep 21, 2022 10:47 pm
I am in the USA, that country just north of Mexico and just south of Canada. :lol:
AlphaXrayPapa
Post by AlphaXrayPapa »
markhiseman wrote: Tue May 03, 2022 2:21 pm I am setting up Meteobridge on a new RPI 4B, but I can't get the WiFi to work. You say on the 'preparing hardware' page that "If you have trouble in making use of WiFi please try previous v1.3 disk image" ... but that doesn't boot, I guess because of the need for an updated boot section. Will you be updating the 1.3 disk image so we can get the WiFi working? Or is there a fix for the 1.4 disk image? Thanks. Mark.
This problem continues to exist as of today. Almost 2 years later.
I've written directly to the developer, but haven't heard anything. Much as you didn't get an answer to your question here.
markhiseman
Yes its frustrating as it means I have use a physical internet connection, which limits where I can put the RPi.
AlphaXrayPapa
The response I got was that my hardware was not compatible. I had a rev 1.2 and rev 1.5 model RPi and neither worked once I configured the WiFi on them.
I'm requesting a refund at this point.
Sorry that you don't get it working on various RPI 4 revisions. Others (including myself) had no problems. Good luck elsewhere!
