Change of Hub cannot find meteobridge NanoSD. **solved**
stewart45
Post by stewart45 »
I recently had to change my hub now I cannot see the Nano to be able to reconfigure it, tried an IP scanner of the network which found nothing it appears as wireless network item on the list of available networks but cannot connect to it cannot find correct password any help gratefully received
Re: Change of Hub cannot find meteobridge NanoSD
stewart45 wrote: Sun Feb 27, 2022 12:44 pm I recently had to change my hub now I cannot see the Nano to be able to reconfigure it, tried an IP scanner of the network which found nothing it appears as wireless network item on the list of available networks but cannot connect to it cannot find correct password any help gratefully received
Manual http://download.meteobridge.com/files/m ... ual-en.pdf
Second page => Initial Setup
Connect your WiFi computing device of choice with the WiFi network “meteobridge-…..”.
Connection is WPA2PSK AES encoded and uses the encryption key “meteobridge”.
The default password is the same as always meteobridge
Maybe, but i do not think so, if you changed the default password on your meteobrdige, it could be using the new password you have set and used before your change of hub.
stewart45
Post by stewart45 »
sorted thanks
