I'm trying to convert a graph of the soil temperature to a graph to show the air quality, so far I can't find it, does anyone know how I can put the sensors in there?
it concerns the following 3 sensors
air0
air1
air2
Gerrit
timeframe=3M # set total time frame to 3 days before today until today
zoom=10D # select actual day
res=hour1 # maximum resolution is 1 hour
engine=js # selects JavaScript engine
gtitle=Bodemvochtigheid # name of graph
gheight=400 # height in pixels of graph
gwidth=550 # width in pixels of graph
glunit=Cbar # unit of left y-axis
grunit=Cbar # unit of right y-axis
gtype=line # type of graph
gnightalpha=10 # set intensity of additinal colorization of area between sunset and sunrise
gnightcolor=#000000 # set color of area between sunset and sunrise
gtrim=0
sid0=th10hum sname0=vocht10cm swidth0=2 ssel0=hum # sensor 0, temperature
sid1=th11hum sname1=vocht20cm swidth1=1 ssel1=hum # sensor 2, temperature
sid2=th12hum sname2=vocht30cm swidth2=2 ssel2=hum # sensor 0, temperature
sid3=th13hum sname3=vocht40cm swidth3=2 ssel3=hum # sensor 0, temperature
