Updating PHP and Templates Nano SD Help needed
EddertonWx
Post by EddertonWx »
Hi
I have a meteobridge Nano SD
SW Version: Meteobridge 5.4 (May 7 2022, build 4207), FW 1.4
Weather DashBoard 9.34
PHP Current PHP version is : 7.2.1
This has been running for some time now all working almost fine.
I have rebooted Nano SD a couple of times.
A lot of the graphs are blank on the Weather Dashboard 34
I read on some boards that I need to update the PHP and templates.
Can someone advise how I do that as I have never done that before. I do not want to brick the device.
All the links on Weather dashboard site seem to gone now. So does that mean it is no longer supported and will not be updated anymore ?
Sorry just new to updating the Nano so any helps would be great.
If Weather dashboard is gone will there be a new dashboard for the Nano ?
One last question
It says on Weather Dashboard on one of the Options made for Android Smart TV, How do I access this page from my Smart TV ?
I am sorry if the info has been posted before but I did do a search on the boards before posting but did not find anything that would help me Sorry
Phillip
Re: Updating PHP and Templates Nano SD Help needed
You don't have to update PHP in order to have the dashboard included with NANO SD running.
When you update system components on your NANO SD chances are good to ruin it. I would not recommend to go that way.
EddertonWx
Hi
Thank you
So How do I go about updting the system I have rebooted it and that is what is installed as above.
Should all the graphs not work and not be blank.
Can you avise is that the latest software and hard ware installed ?
If not can you advise how I update it,
Many thanks for any help
Phillip
Sorry, I don't have a crystal ball to guess what you do wrong. You have to provide information someone can work with.
1) What settings did you apply to feed the dashboard? Screen dumps?
2) Does data come in from the weather station? Do the predefined charts like "allinone-iso" show data?
3) What does "Live Data - raw" tab show?
4) Any interesting messages in "System - Logfiles" tab?
5) How exactly does your Dashboard look? Screen dumps?
6) Did you try reinstall of the dashboard as presented as option on the "Push Events" tab for the hopefully selected dashboard service?
