Help - Problems with Barometric Pressure
RickNY
Post by RickNY »
Hi.. I am having problems with Meteobridge where randomly, my barometric pressure stops updating on my CWOP uploads. When this happens, my Meteobridge graphs also show no updates for pressure and my 5-minute data also shows no changes. What is strange is that my live sensor data still continues to update with the proper values, and my uploads to WeatherUnderground do get the correct updated barometer readings, as does the data that my WeatherDisplay software is pulling from the Meteobridge. This has happened twice so far since I migrated from Meteohub to Meteobridge on RPI around 3 weeks ago. Restarting the Meteobridge gets it reporting properly again. I am connected to a Vantage Pro 2 with a Davis Weatherlink IP logger.
I am currently running on a RPI Model 4B with Meteobridge 5.4 (May 31 2022, build 2784), FW 1.4
I migrated from Meteohub around 3 weeks ago, and never experienced this issue on that.
RickNY
Re: Help - Problems with Barometric Pressure
Post by RickNY »
Attached a graph of what CWOP gets.. My uploaded data is in blue. When this starts, Meteobridge will continue just sending the same value to CWOP for pressure -- even when the live data is showing new values.
