Migration TP-Link MR3020V1.9 to MR3020V3
petey
Post by petey »
Just seeing this in the logging when starting up MR-3020V3. I did not see this when starting MR-3020V1.
setup  (16.06.2022 07:47:31): use UTC stamp 2022-06-16 12:47:31 (1 tries)
wnetd  (16.06.2022 07:47:41): process started.
system (16.06.2022 07:47:41): start of logging process initiated.
wnetd  (16.06.2022 07:47:41): send data thread started (pid:1934 tid:1935)
logger (16.06.2022 07:47:42): historical data loaded (30 records).
logger (16.06.2022 07:47:42): data logger (version 5.4, build 4216) started.
[b]logger (16.06.2022 07:47:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: Invalid argument
logger (16.06.2022 07:47:42): station 0 (Meteostick Vantage), connect to station failed.[/b]
logger (16.06.2022 07:47:46): sensors are now providing data.
logger (16.06.2022 07:47:46): services started.
[b]logger (16.06.2022 07:48:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: Invalid argument
logger (16.06.2022 07:49:12): message above repeats 2 times.
logger (16.06.2022 07:49:42): connect station 0 (Meteostick Vantage via USB serial).
logger (16.06.2022 07:49:44): station 0 (Meteostick Vantage), transmitter 5 registered as ISS
logger (16.06.2022 07:49:44): station 0 (Meteostick Vantage), Meteostick Version 2.5.2[/b]
logger (16.06.2022 07:49:44): station 0 (Meteostick Vantage), debug off
logger (16.06.2022 07:49:44): station 0 (Meteostick Vantage), verbose off
logger (16.06.2022 07:49:44): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (16.06.2022 07:49:44): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (16.06.2022 07:49:44): station 0 (Meteostick Vantage), filter on
logger (16.06.2022 07:49:44): station 0 (Meteostick Vantage), rx threshold set to -90db
logger (16.06.2022 07:49:44): station 0 (Meteostick Vantage), listening to transmitter 5
logger (16.06.2022 07:49:44): station 0 (Meteostick Vantage), bandwidth narrow
logger (16.06.2022 07:49:44): station 0 (Meteostick Vantage), chip authentication ok: 14
logger (16.06.2022 07:49:44): station 0 (Meteostick Vantage), frequency band 915MHz (US)
I cannot update the Meteostick with the MR-3020V3. I could with the MR-3020V1.
Is it starting the logger too fast?
Auto Mator
Re: Migration TP-Link MR3020V1.9 to MR3020V3
Seems just to be an issue in regard to setting up the serial devices on startup. Looks like it finally kicks in correctly after a few seconds.
