delta24h **solved**
- jmontamat
delta24h **solved**
From the
released July 16, 2022
[th0temp-delta24h:--]
it doesn't work well on RPI Raspberry Pi 4 Model B and
Raspberry Pi 3 Model B, but it works well on TP-link ?
After waiting more than 24 hours
Re: delta24h
Hi, I can confirm that the trend works on the Raspberry Pi 4 Model B RPI. I use it and it answers me correctly.
- jmontamat
Re: delta24h
The database is fine according to the 24h charts but all the trends give wrong values, before it worked fine.
- Sin título.png (14.99 KiB) Viewed 8897 times
- jmontamat
Re: delta24h
Investigating the delta 24h theme gives me the result of the difference of the current value with today's minimum eg: current temperature 28.2, today's minimum 21.1[th0temp-delta24h:--] = +7.0 .
I specifically acquired these two RPI licenses so that this would not happen to me like TP-link when it runs out of RAM
- Sin título.png (16.69 KiB) Viewed 8839 times
Re: delta24h
So what was the actual temperature at the same time yesterday relative to the time of the current temperature being 28.2?
- jmontamat
Re: delta24h
Since there is no answer for this problem neither here nor via email, I go back to using my more reliable Mysql database.
Thanks to masgio69 Mattk for his interest
Re: delta24h
Interest was one thing, an answer would have been a positive approach?
- jmontamat
Re: delta24h
I appreciate the answers that can be of help, I guess I have something misconfigured something has been confusing for me delta24h Mysql has always worked well for me.Mattk wrote: Thu Jul 21, 2022 11:05 am Interest was one thing, an answer would have been a positive approach?
Re: delta24h
Hello, as I wrote in previous posts in my case the 24 h trend works very well and thanks to the forum I have created other trends (this is a page that I created with tags http://meteopiova.altervista.org/trend/ ). It seems strange to me that it doesn't work as it is a standard trend. Isn't it by chance that you are looking for a function using the wrong tag?
- jmontamat
Re: delta24h
I use these:masgio69 wrote: Thu Jul 21, 2022 6:26 pm Hello, as I wrote in previous posts in my case the 24 h trend works very well and thanks to the forum I have created other trends (this is a page that I created with tags http://meteopiova.altervista.org/trend/ ). It seems strange to me that it doesn't work as it is a standard trend. Isn't it by chance that you are looking for a function using the wrong tag?
[th0temp-delta24h:--] [th0hum-delta24h:--] [th0dew-delta24h:--] [thb0seapress-delta24h:--]
on TP-Link they work fine but not on RPI, with a station GW1000, a mystery
- jmontamat
Re: delta24h
One last observation with whether Davis station works well for you
me with
With station Oregon WMRS200 ok
but with Ecowitt GW1000 + WS80 station NO, won't this be the problem?
me with
Re: delta24h
I am working on the problem.
Please try just released update and give it 24h to have delta24h operational again.
- jmontamat
Re: delta24h
Waiting for results after update
released July 25, 2022
Thanks Boris.
Thanks Boris.
- jmontamat
Re: delta24h
Good morning after + 24hadmin wrote: Mon Jul 25, 2022 10:52 pm I am working on the problem.
It works correctly delta24h in
Platform: Raspberry Pi 3 Model B
I consider the issue resolved.
Re: delta24h
Hi, I found that I have the same problem on my rasberry 4, I did as you said but I still have the same problem. What do you recommend? Thank you!!
