MB Pro build 14794 system stalled **solved**
Gyvate
Post by Gyvate »
ever since my MB Pro loaded 14794, the processes are stalled
repeated reboot or power cycling doesn't make any change
the system log shows only: (e.g.)
oled (04.08.2022 04:59:07): process started.
setup (04.08.2022 07:07:31): use UTC stamp 2022-08-04 05:07:31 (1 tries)
test5m (04.08.2022 07:08:49): weathernet daemon stalled, will be restarted now.
wnetd (04.08.2022 07:08:49): process started.
test5m (04.08.2022 07:08:49): logger stalled, will be restarted now.
system (04.08.2022 07:08:49): stop of logging process initiated.
wnetd (04.08.2022 07:08:49): send data thread started (pid:2592 tid:2593)
and that was it ....
also after 10 minutes no change in the logging
- wanting to display a chart brings the GUI message that the database can't be opened
- history data can't be retrieved - only "--" everywhere ...
after 12 minutes two more entries:
test5m (04.08.2022 07:21:15): logger stalled, will be restarted now.
system (04.08.2022 07:21:15): stop of logging process initiated.
test5m (04.08.2022 07:30:40): logger stalled, will be restarted now.
system (04.08.2022 07:30:40): stop of logging process initiated.
this keeps repeating every 9-10 minutes
until that new release MB was running fine - with a few spontaneous reboots every now and then
(but it does this already "for ages"; sometimes once day, sometimes after a few days ..., I got used to it
and as long as no data was lost I wouldn't mind)
Please advise
Re: MB Pro build 14794 system stalled
I did an update on 1 MBPro on 1/8/22 for Version 5.4 released July 25/26/28, 2022 (currently the latest release), and that shows build 14790, there doesn't appear any issues with that so far? What is the release date for this build 14794?
Gyvate
Post by Gyvate »
Meteobridge 5.4 (Aug 2 2022, build 14794), FW 1.4
it was on 14790 before too and no issues
Gyvate
Post by Gyvate »
Looks like it's working again properly with the just released
Meteobridge 5.4 (Aug 4 2022, build 14798), FW 1.4
