Evapotranspiration
DarthWeber
Evapotranspiration
Post by DarthWeber »
is there any way to add the evapotranspiration to the livedataxml.cgi ?
Until now i do a http request with template.cgi?template=[sol0evo-act] but this seems to be unstable, it leads sometimes to an gateway error. I am also not too happy with the daysum and ydaysum selectors as i wish to get the value for the last 24 hours or 48 hours.
Is there any way ?
warm regards,
Tom
Re: Evapotranspiration
A gateway error would tend to indicate a network issue? Define unstable?
What platform are you running?
DarthWeber
requests are from raspbian. But a pure network issue could not explain that the livedataxml.cgi still works - With unstable i mean that I had only 3 out off 280 succesful readings yesterday. All of the livedataxml.cgi where succesful.
MBPro Additions support @h24 and @h48 being 24 hours and 48 hours in the past but as ET is only recorded by Davis stations every hour then unsure exactly what the results might be in between, possibly zero?
