Cannot add indoor THB sensor again
miraculon
Post by miraculon »
My old VUE console had a bad barometer, so I didn't have THB0 selected on meteohub.
I recently decided to connect another VUE console with a good barometer in its place.
Initially I could see a selection under Sensors for "indoor" and I chose THB0 and gave it a name. If I don't select an ID and give it a name, it appears to be accepting the data. Once an ID/Name is assigned it breaks...
Ever after, I get:
error connect socket 127.0.0.1:5555 :Connection refused
Warning: Data logging has been halted.
If I deselect the indoor/THB0 selection (and delete the name), it will eventually find the wind, rain and outdoor sensors and everything works again.
I even did a reset and re-entered my registration key and station info thinking that something was "left over" from before. I even tried adding it as an "Additional ID", which seemed at first like it "took" it, but no plot resulted barometer graph.
Greg H.
Screenshot 2022-08-29 at 14-23-25 MeteoHub.png (42.84 KiB) Viewed 38893 times
