RPi 4 Updates
2thepoint
RPi 4 Updates
Post by 2thepoint »
I've been experiencing RPi4 connection issues for a few months now. Several times a month the connection drops requiring either a reboot which is not a big deal or a power cycle which can be a pain. Would updating the RPi4 help?? Are there any other options I can try to stabilize the environment??
My isp config is stable and the MB ip address shows active on my router although MB is down.
thanks for any help....
Re: RPi 4 Updates
If you are connected via WiFi there might be problems when your Router/AP does change WiFi channels on the fly. Most routers can have this disabled.
2thepoint
solved****Re: RPi 4 Updates****solved
Post by 2thepoint »
Admin,
NO wifi.....I believe the culprit was a bad ethernet cable that had a broken lock tab. Hopefully things will return to normal.
thanks for the reply.
