Local Dashboard Weather 34 not working. **solved**
IVD
Post by IVD »
hello,
I cannot get the local dashboard Weather 34 to work after a reboot. The reported error is 'The requested URL was not found on this server'. I am using version 5.5. I have installed 'Local Dashboard' on the Weather Nets tab. I clicked on 'Reinstall Dashboard' on the Weather Dashboard tab and clicked save. What else can I do? I have used the local weather dashboard since I have the Meteobridge NanoSD (3 years ago) without any problems but this problem has only started in the last few weeks. I hope to get this to work again as it is one of the great features included in the nano.
Re: Local Dashboard Weather 34 not working
I have no idea what goes wrong. May be easiest option to get this solved is to give me remote access so that I can try and inspect myself. Please direct credentials to "info(at)meteobridge.com".
IVD
Post by IVD »
The problem is now solved since I downloaded the latest Meterobridge 5.5 FW1.4 from 28 December 2022. I rebooted and loaded the latest version of the software several times between late October (since the Meteobridge server crashed) and the end of December and the local Dashboard never worked. I was so please when both dashboards started to work again with the latest software update.
