Weather34 and Aurora Dashboards on PRO2. **solved**
chrysnic
Post by chrysnic »
Hi all,
I have just migrated from the Meteobridge PRO to the PRO2. I successfully transferred my PRO configuration to the PRO2 and everything seems to be OK.
I enabled the "Feed Dashboard with data" checkbox under "Live Data"->"Weather Dashboard". However, when I click the "Launch Weather34 Dashboard" button, there is no data in the dashboard. The same is true for the Aurora Dashboard. Is there anything else I need to configure for those dashboards to show my live data?
Thank you very much for the help,
Chrysnic
IVD
Re: Weather34 and Aurora Dashboards on PRO2
Post by IVD »
Hi Chris,
I posted the same problem on this forum on the 16th of November. It is still not solved.
chrysnic
Post by chrysnic »
Thanks IVD. After reading your post, I think the difference in my case is that I do not get any error message. The dashboard opens in a new tab (after I click the "Launch Weather34 Dashboard" button), but the dashboard does not contain any live data.
Did you enable sending data to the dashboard?
chrysnic
Post by chrysnic »
Do you mean checking the box that says "Feed Dashboard with data" on the "Weather Dashboard" tab? Yes, I have done that.
chrysnic
chrysnic
Post by chrysnic »
This is very strange: I have just checked it again, and now it appears to show live data correctly! It was definitely not showing anything for the last few days (since I started using the PRO2), but now it appears to be alive. I will keep checking to make sure everything is OK.
Chrysnic
