Mastodon support
WessexWeather
Mastodon support
Post by WessexWeather »
With so many people leaving Twitter for Mastodon, would it be possible to add Mastodon as a Service?
Simon
Re: Mastodon support
I have to inspect how to implement that. I put it on the wish list.
ConligWX
Post by ConligWX »
If twitter pulls the plug on the free API then that would a great idea to implement an alternative to post too.
WessexWeather
Twitter has finally pulled the plug, so the built-in Twitter event is no longer working. Twitter's days appear to be numbered, especially following the recent X rebrand.
Have you had a chance to look into Mastodon support?
Simon
ConligWX
Post by ConligWX »
following.....
Churchtownweather
Post by Churchtownweather »
Following
ConligWX
Post by ConligWX »
What needs to be done is a server setup for weather.
There is a meteo.social but it's not accepting any new users.
WessexWeather
That’s true, but this thread is about adding Mastodon support to Meteobridge…
Simon
ConligWX
Post by ConligWX »
WessexWeather wrote: Mon Jul 31, 2023 12:15 am That’s true, but this thread is about adding Mastodon support to Meteobridge…
for the time being I am gonna use the cli toot utility for Mastodon and then "toot" post a file content (made by metoeobridge or CumulusMX) to this server:
https://wxcloud.social/
before Twitter support in Meteobridge I used a similar method with twidge
WessexWeather
Thanks Simon, can you tell us a bit more about this? I’m not familiar with it.
Simon
ConligWX
Post by ConligWX »
so I am probably going to use my cumulusMX server (ubuntu) to "toot" a post from a file.
CumulusMX allows me to create a template with cmx values (similar to what metoebridge should be able to do) this template is processed and writes to a file.
the file contents are then used to post onto mastodon using a cron job using the cli command installed from this package.
https://toot.bezdomni.net/
the command line will look something like this:
some bash script command line.....
cat  mastodon.txt | toot post >> toot.out 2>> toot.err
The file "mastodon.txt" has the weather values that I'm posting.
"toot" is the "toot" binary file, so
that is the command being executed.
"post" is the parameter I'm passing to "toot" to tell it to post
the content that has been piped into it.
">> toot.out" means the output of the command is to be appended
to the file "toot.out"
"2>> toot.err" means any error output from the command will be
appended to the file "toot.err"
hope that helps. I'm not sure if you could install toot onto meteobridge itself and run it locally or you can save the file contents elsewhere and use toot from another linux device. then call the commandline from a crontab task.
src: https://lists.sr.ht/~ihabunek/toot-disc ... s.co.uk%3E
WessexWeather
Thanks Simon, I’ll look into this.
I just wish Boris could implement this natively as he has with other services. Maybe it’s not as easy as we think.
Simon
ConligWX
Post by ConligWX »
WessexWeather wrote: Wed Aug 02, 2023 7:29 pm Thanks Simon, I’ll look into this.
the hardest part was the registration process for the cli tool via CLI command. it just didn't work for me, but it does give you a URL to use. once the url was used in chrome, then registration process worked. using
# toot post "whatever text your like"
does work now. I will be testing out the "toots" this weekend and hopefully have it up and running soon.
ConligWX
Post by ConligWX »
ConligWX wrote: Fri Aug 04, 2023 8:57 am does work now. I will be testing out the "toots" this weekend and hopefully have it up and running soon.
Finally got it working, or there abouts....
https://wxcloud.social/@conligwx
Nice reading. Unfortunately, toot is based on python which Meteobridge does not support (because of storage limitations).
