data export (last 7 days) has problems at the turn of the year
WetterCH
Post by WetterCH »
I have the MB-Pro which makes the data available to WsWin as an export. this is done daily, but since 2023 the Meteobridge only creates an export file until 12/31/2022 11:55 p.m. do some of you also have this problem?
If I select the period (current month) it works without any problems and I get the data from January 2023.
Re: data export (last 7 days) has problems at the turn of the year
No, do not see that issue across several MBPro's & Nano Data Exports across 2022/2023.
Data Exports are [before each new day], [Current Day] and [Minutes] with files for the 1/1/2023 all good.
