Air quality readings aurora **solved**
Churchtownweather
Post by Churchtownweather »
Hi anyone else having problems getting their air quality readings to display
Any help would be greatly appreciated
Many thanks
IVD
Re: Air quality readings aurora
Post by IVD »
I also do not see my Davis Airlink data on either Aurora or Weather 34. I did indicate in the setup menu of both that I have an Airlink (not Purple Air or Luftdaten) but my data are not displayed in the air quality window. Some data is displayed (always the value 30) and I have no idea where that comes from.
The problem of the initial prost was related by a locked-up airlink, which returned into operation after a reboot, as far as I remenber.
The second post might try the check the "Station - Mapping" tab to make sure the sensor is mapped to the right airXpm sensor name.
IVD
Re: Air quality readings aurora **solved**
Post by IVD »
All are mapped
Physical Sensor Logical Sensor Meaning
air1!0pm air0pm air quality (10 microns or default)
air1!1pm air1pm air quality (2.5 microns)
air1!2pm air2pm air quality (1 micron)
IVD
Post by IVD »
This problem is not solves as the sensors are mapped but the sensors and data are not shown under Raw data nor Min/max data
