Where to purchase PRO2 from USA?
JPB
Post by JPB »
Hi - I reside in the USA, and have no idea where I can purchase a Meteobridge PRO2. I can find the "WeatherBridge PRO" - but I have no reason to believe that if I purchase, they will give me a PRO2. They may be working through their remaining stock of PROs, for all I know.
Any ideas?
BigAlT
Re: Where to purchase PRO2 from USA?
Post by BigAlT »
The only authorized US reseller is Ambient Weather which does not list the Pro2. Just the Pro , which is called Weatherbridge. They may be offering it soon as the Pro 1 is no longer in production. You might contact them to find out. support@AmbientWeather.com or phone (480) 346-3380.
If you don’t want to wait you can order one from the Swiss reseller :
https://meteobridge.shop/weatherBoxx-PR ... O-Lizenz_1
They are very reliable as I purchased my Nano SD from them. I don’t know if they have the US Voltage ( 110v ) power supply. With the Nano it wasn’t important as it draws power from the Davis Pro 2.
The Pro2 uses a micro c USB power supply so even if they send you a European power supply, any 110v USB Power Supply with a micro-c connector will work fine.
PRO 2 uses the same Micro USB (not a c) as the PRO
BigAlT
Post by BigAlT »
My apologies. I misread the description of the power socket on the website. As the power requirements are even less than the Pro, any 3 amp USB to micro power supply should be more than adequate.
Currently we lack a reseller of PRO2 in the US, but we can send directly from Germany. Please contact "info@smartbedded.com" for an offer. Package includes a power supply with EU/UK/US adapter, so no problem an that side.
