WSWIN Data Feed dont work **solved**
xray77
Post by xray77 »
Unfortunately the WSWIn Data Feed does not work with my Meteobridge Nano SD: As soon as I activate it in the Weather Networks tab, the Nano SD's buffer gets fuller and fuller quite fast and later the log shows the message "cannot malloc 22937952 bytes for table read". After that the Nano SD has to reboot, otherwise it can't handle the other tasks anymore.
How do I get this WSWIN Data Feed to run?
Edit: Have solved the problem: In the meteobridge-export directory existed an old huge hidden .export.csv file, after deleting this file it now works!
Thanks and best regards
Mike
Re: WSWIN Data Feed dont work (solved)
Thanks for finding that solution path.
