Nano SD. **solved**
saroyan17
Nano SD. **solved**
Post by saroyan17 »
I replaced my Meteolink with a Meteobridge Nano SD.
For some files like clientraw.txt the data does not reach the created file. It always remains at zero. What can I do to get the data from the meteobridge into the file?
Thank you for your help,
Re: Nano SD
What exactly do you miss? I the file empty at all or not as fully populated as you expect?
saroyan17
Re: Nano SD
Post by saroyan17 »
Thank you for your answer.
I asked Infoclimat who solved my problem.
