Nano SD ** solved **
saroyan17
Post by saroyan17 »
I'm contacting you again, because I've just realised that with the meteobridge Nano the indoor temperature displayed by the vantage is not correct. It is about two degrees higher!
Is there anything that can be done? Maybe this is due to the Nano!
Re: Nano SD
Yes that's a known occurrence with electronics that run hotter than surrounding ambient temperatures. Review the August 26, 2018 release on this page
https://www.meteobridge.com/wiki/index.php/Forum
Make the appropriate adjustment offset under [WeatherStation]>[Primary Station] Tick Configure Console logging interval .... etc > Input offset value, Select C or F and Save.
saroyan17
Re: Nano SD
Post by saroyan17 »
I have found what to do, but it doesn't seem to work on the vantage station!
Is this normal?
Re: Nano SD
Please apply again and post the "System - Log File" results. There should be a remark in the log if the settings have been applied. Also live data readings for inside temperature should be affected on next data read. You can play with different settings to see it working.
saroyan17
Re: Nano SD
Post by saroyan17 »
I hope I understood the meaning of your request.
Here are the logs from the newspaper. On the Vantage station the temperature has not been modified.
logger (04.02.2023 17:04:45): station 0 (Vantage), wakeup sent.
logger (04.02.2023 17:04:48): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (04.02.2023 17:04:48): services paused.
logger (04.02.2023 17:04:49): station 0 (Vantage), no need to update console date/time.
logger (04.02.2023 17:04:50): station 0 (Vantage), setup script executed.
logger (04.02.2023 17:04:50): station 0 (Vantage), internal logger activated.
logger (04.02.2023 17:04:50): station 0 (Vantage), syncing.
logger (04.02.2023 17:05:01): station 0 (Vantage), gettime request sent.
logger (04.02.2023 17:05:01): station 0 (Vantage), no Vantage time offset.
logger (04.02.2023 17:05:01): station 0 (Vantage), eeprom request sent.
logger (04.02.2023 17:05:01): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (04.02.2023 17:05:01): station 0 (Vantage), transmitter 1 active as station type #1 "Temp Only" mapped to "t1".
logger (04.02.2023 17:05:01): station 0 (Vantage), transmitter 3 active as station type #3 "Temp/Hum" mapped to "th3".
logger (04.02.2023 17:05:01): station 0 (Vantage), transmitter 4 active as station type #4 "Wind".
logger (04.02.2023 17:05:01): station 0 (Vantage), transmitter 6 active as station type #7 "Soil".
logger (04.02.2023 17:05:01): station 0 (Vantage), firmware version request sent.
logger (04.02.2023 17:05:01): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (04.02.2023 17:05:01): station 0 (Vantage), no reading of Vantage's internal logger.
logger (04.02.2023 17:05:06): sensors are now providing data.
logger (04.02.2023 17:05:06): services started.
system (04.02.2023 17:10:12): stop of logging process initiated.
system (04.02.2023 17:10:20): start of logging process initiated.
logger (04.02.2023 17:10:20): databases connected. Update interval 3600 seconds.
logger (04.02.2023 17:10:20): data logger (version 5.4, build 4353) started.
logger (04.02.2023 17:10:21): connect station 0 (Vantage via serial).
logger (04.02.2023 17:10:21): connect station 9 (System Data via Plug-in).
logger (04.02.2023 17:10:21): station 0 (Vantage), wakeup sent.
logger (04.02.2023 17:10:24): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (04.02.2023 17:10:24): services paused.
logger (04.02.2023 17:10:25): station 0 (Vantage), no need to update console date/time.
logger (04.02.2023 17:10:25): station 0 (Vantage), setup script executed.
logger (04.02.2023 17:10:25): station 0 (Vantage), internal logger activated.
logger (04.02.2023 17:10:25): station 0 (Vantage), syncing.
logger (04.02.2023 17:10:35): station 0 (Vantage), gettime request sent.
logger (04.02.2023 17:10:35): station 0 (Vantage), no Vantage time offset.
logger (04.02.2023 17:10:35): station 0 (Vantage), eeprom request sent.
logger (04.02.2023 17:10:35): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (04.02.2023 17:10:35): station 0 (Vantage), transmitter 1 active as station type #1 "Temp Only" mapped to "t1".
logger (04.02.2023 17:10:35): station 0 (Vantage), transmitter 3 active as station type #3 "Temp/Hum" mapped to "th3".
logger (04.02.2023 17:10:35): station 0 (Vantage), transmitter 4 active as station type #4 "Wind".
logger (04.02.2023 17:10:35): station 0 (Vantage), transmitter 6 active as station type #7 "Soil".
logger (04.02.2023 17:10:35): station 0 (Vantage), firmware version request sent.
logger (04.02.2023 17:10:35): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (04.02.2023 17:10:35): station 0 (Vantage), no reading of Vantage's internal logger.
logger (04.02.2023 17:12:21): give up waiting for sensors after 120 secs.
logger (04.02.2023 17:12:21): services activated.
system (04.02.2023 17:45:33): stop of logging process initiated.
system (04.02.2023 17:45:40): start of logging process initiated.
logger (04.02.2023 17:45:41): databases connected. Update interval 3600 seconds.
logger (04.02.2023 17:45:41): data logger (version 5.4, build 4353) started.
logger (04.02.2023 17:45:42): connect station 0 (Vantage via serial).
logger (04.02.2023 17:45:42): connect station 9 (System Data via Plug-in).
logger (04.02.2023 17:45:42): station 0 (Vantage), wakeup sent.
logger (04.02.2023 17:45:45): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (04.02.2023 17:45:45): services paused.
logger (04.02.2023 17:45:45): station 0 (Vantage), no need to update console date/time.
logger (04.02.2023 17:45:49): station 0 (Vantage), setup script executed.
logger (04.02.2023 17:45:49): station 0 (Vantage), internal logger activated.
logger (04.02.2023 17:45:49): station 0 (Vantage), syncing.
logger (04.02.2023 17:45:59): station 0 (Vantage), gettime request sent.
logger (04.02.2023 17:45:59): station 0 (Vantage), no Vantage time offset.
logger (04.02.2023 17:45:59): station 0 (Vantage), eeprom request sent.
logger (04.02.2023 17:45:59): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (04.02.2023 17:45:59): station 0 (Vantage), transmitter 1 active as station type #1 "Temp Only" mapped to "t1".
logger (04.02.2023 17:45:59): station 0 (Vantage), transmitter 3 active as station type #3 "Temp/Hum" mapped to "th3".
logger (04.02.2023 17:45:59): station 0 (Vantage), transmitter 4 active as station type #4 "Wind".
logger (04.02.2023 17:45:59): station 0 (Vantage), transmitter 6 active as station type #7 "Soil".
logger (04.02.2023 17:45:59): station 0 (Vantage), firmware version request sent.
logger (04.02.2023 17:45:59): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (04.02.2023 17:45:59): station 0 (Vantage), no reading of Vantage's internal logger.
logger (04.02.2023 17:47:42): give up waiting for sensors after 120 secs.
logger (04.02.2023 17:47:42): services activated.
system (04.02.2023 18:50:51): Access point operation disabled 181735 secs after boot.
system (04.02.2023 18:56:35): stop of logging process initiated.
system (04.02.2023 18:56:42): start of logging process initiated.
logger (04.02.2023 18:56:43): databases connected. Update interval 3600 seconds.
logger (04.02.2023 18:56:43): data logger (version 5.4, build 4353) started.
logger (04.02.2023 18:56:44): connect station 0 (Vantage via serial).
logger (04.02.2023 18:56:44): connect station 9 (System Data via Plug-in).
logger (04.02.2023 18:56:44): station 0 (Vantage), wakeup sent.
logger (04.02.2023 18:56:47): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (04.02.2023 18:56:47): services paused.
logger (04.02.2023 18:56:48): station 0 (Vantage), no need to update console date/time.
logger (04.02.2023 18:56:49): station 0 (Vantage), setup script executed.
logger (04.02.2023 18:56:49): station 0 (Vantage), internal logger activated.
logger (04.02.2023 18:56:49): station 0 (Vantage), syncing.
logger (04.02.2023 18:57:00): station 0 (Vantage), gettime request sent.
logger (04.02.2023 18:57:00): station 0 (Vantage), no Vantage time offset.
logger (04.02.2023 18:57:00): station 0 (Vantage), eeprom request sent.
logger (04.02.2023 18:57:00): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (04.02.2023 18:57:00): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (04.02.2023 18:57:00): station 0 (Vantage), firmware version request sent.
logger (04.02.2023 18:57:00): station 0 (Vantage), firmware version 1.90 (supports LOOP2)
logger (04.02.2023 18:57:00): station 0 (Vantage), no reading of Vantage's internal logger.
logger (04.02.2023 18:58:44): give up waiting for sensors after 120 secs.
logger (04.02.2023 18:58:44): services activated.
system (06.02.2023 07:41:09): Disconnected from WLAN or Internet, reconnect issued.
system (06.02.2023 07:41:16): Access point operation temporarily enabled.
system (06.02.2023 07:46:09): Access point operation disabled 314653 secs after boot.
Thank you
saroyan17
Re: Nano SD
Post by saroyan17 »
I just found my mistake. I had placed a comma instead of a period in the temperature rise compensation. :D
