Davis Airlink connects to NANO but no data collected
IVD
Post by IVD »
My Airlink was working well with my NanoSD until a powercut a few days ago. My NanoSD and Davis weather station rebooted fine when the electricity came on again. The Airlink also rebooted and connected with Davis Weatherlink as well as the NanoSD but no data are collected by the Nano. The
sensors are mapped (as shown below)
Physical Sensor Logical Sensor Meaning
air1!0pm air0pm air quality (10 microns or default)
air1!1pm air1pm air quality (2.5 microns)
air1!2pm air2pm air quality (1 micron)
However, the sensors are not listed on 'Raw Sensor Data' and 'Min/Max data'. The History tab shows no data have been collected since the powercut. The Airlink is working because I can see the data on the Weatherlink site. I am puzzled that the senors are mapped on the NanoSD but then do not seem to collect the data. Any idea what is going on? I am running Meteobridge 5.5 (18 Janurary 2023).
ConligWX
Re: Davis Airlink connects to Nana but no data collected
Post by ConligWX »
did your airlink perhaps change IP address?
IVD
Post by IVD »
I checked the IP address and it has not changed.
ConligWX
Post by ConligWX »
Try rebooting meteobridge and the airlink device I guess
IVD
Post by IVD »
I have already done that and it does not make any difference. Logging shows that Airlink is connected and I can again see the mapped sensors but no data.
Haven't that been caused by a locked-up Airlink which operates fine again after reboot? Hopefully. I do not mix up with a similar issue we solved via PM.
IVD
Re: Davis Airlink connects to NANO but no data collected
Post by IVD »
Rebooting Airlink and Meteobridge does not solve the problem. I have now done this 3 times over the last 2 days. Airlink is always mapped but no data are displayed or collected. Files I download are empty.
IVD
Post by IVD »
I still have not been able to get Meteobridge to collect Airlink data. The sensors are still mapped and the following message is displayed in the Logging:
logger (12.02.2023 11:31:33): station 1 (AirLink), no synchronization for 900 seconds, data logger will be restarted.
logger (12.02.2023 11:31:33): disconnect station 1 (AirLink): timeout
logger (12.02.2023 11:32:03): connect station 1 (AirLink via SW Driver).
This message is repeated in Logging every 15 minutes. I hope somebody can tell me what this message means and how I can solve the problem. The Airlink is connected with my WiFi (I see data on the Davis website) and I have no idea how I can syncronise it with Meteobridge.
Can you please give me a remote login? Please send credentials to "info(at)meteobridge.com".
Re: Davis Airlink connects to NANO but no data collected. **solved**
Inspection turned out that the IP for addressing the Airlink was wrong. :roll:
IVD wrote: Mon Feb 06, 2023 9:35 pm I checked the IP address and it has not changed.
Sorry you did NOT! How did you do the check?
