Had to re-power my meteobridge and now it just cycles. The last of the landing page look like:
Address 1: 2a01:4f8:272:5216::4711 tau.meteobridge.com
Address 2: 162.55.245.30 tau.meteobridge.com
I can open a terminal shell onto the device. It looks like the wget runs OK, then there is a tar process running. After this is re-boots so difficult to get a logs. I can get a tail of /tmp/image.log before it reboots:
4350K .......... .......... .......... .......... .......... 94% 192K 1s
4400K .......... .......... .......... .......... .......... 95% 676K 1s
4450K .......... .......... .......... .......... .......... 96% 209K 1s
4500K .......... .......... .......... .......... .......... 97% 888K 0s
4550K .......... .......... .......... .......... .......... 98% 747K 0s
4600K .......... .......... .......... .......... .......... 99% 191K 0s
4650K .......... .......... .. 100% 1.43M=14s
2022-12-06 09:40:56 (334 KB/s) - '/tmp/image.tgz' saved [4785018/4785018]
Anyone got some ideas please?
Cycling at boot up. **solved**
Re: Cycling at boot up
Sorry, guys, after quite some time and many reboots it finally came good.
Re: Cycling at boot up. **solved**
You had the same issue? What are you running? Tp link?
