PRO2 - SMB Password fails to Logon **Solved**
Has anybody set a password on the SMB share and it has worked? Same SMB password action on the PRO works fine.
Accessing the PRO2 SMB share is fine when set to [SMB Guests only] but set to [SMB User only] and having changed the SMB password comes up with a Logon failure?
Re: PRO2 - SMB Password fails to Logon
I tested changing SMB password on PRO2 and it works. Please make sure that you login via SMB as user "meteobridge".
Ok what it is is a SMB/WinOS thing, the PRO/SMB version has issues with some Win10 systems but not with Win7 etc, now it's the reverse, PRO2 bails up with Win7 but not Win10.
Re: PRO2 - SMB Password fails to Logon **Solved**
Damn, not sure if I can fix this.
