Resetting Meteobridge PRO 2 **solved**
Posted: Wed Mar 29, 2023 9:03 am
by MGS
I have managed to make my MB Pro 2 a little unstable, every so often it comes up with some DB full errors and other messages. I have been importing lots of historic Data but the SD card is only reporting 14% full so I am confident its not full and new sensor data is being written so that is all ok.
When going in to Import/Export the MB system hangs and eventually restarts the logging services sometimes I have to reboot
I have tried the DB check and rebuild options and they went through successfully but the problem still is there.
I have got to the point where I want to just start again and reset the Pro 2 back to factory fresh out of the box state, I have tried a Factory Reset this only seems to reset the config back to an out of the box state and leaves the DB intact. Is there a way of fully reset the Pro 2 which includes a database reset?
I have all of my data so I am not worried about loosing any data.
Any help would be great on this.
Mark.
Re: Resetting Meteobridge PRO 2
Posted: Wed Mar 29, 2023 10:49 am
by MGS
Example of the Database full error from today.
Database Error.png (81.04 KiB) Viewed 703 times
Meteobridge Pro 2 System Information Page
sys info.png (53.27 KiB) Viewed 703 times
Posted: Sun Apr 02, 2023 10:45 am
by MGS
Resolved this by SSH'ing to the Meteobridge and deleting the dbase* files in /tmp/nmt, then rebooting the Meteobridge which re created new empty files! :)
