Rainfall graphs not working
oliverb
Post by oliverb »
Is there a problem with some of the Rainfall graphs?
31 day works fine but 24hr 7day and 12month show no data.
Is this a known issue that is being worked on?
By the way thanks for adding WDL support to Meteohub.
Brett.
oliverb
Re:Rainfall graphs not working
Post by oliverb »
Just noticed there are now 4 WDL txt files to upload in Graph uploads.
Only 1 of mine was set. I have now set all 4 so will check gpaphs again later.
oliverb
Post by oliverb »
Update.
Only the 7 day and 12month graphs do not work.
I've also noticed the daily and monthly rain guages to not match up.
See enclosed pic the daily is higher than the monthly guage.
Brett. Image
monthly data is computed every 6 hours, daily every hour. When being at the beginning of a month and you actually have some significant rain, this can explain your finding. The problem will fade during the next couple of hours.
oliverb
Post by oliverb »
I see this post is marked as "solved" but my 7 day and 12 months graphs still show no data.
http://home2.btconnect.com/brettoliver/graph.html
Brett.
wfpost
Post by wfpost »
oliverb wrote:I see this post is marked as "solved" but my 7 day and 12 months graphs still show no data.
Brett.
I can confirm Bretts observation.
The same issue is with wind graphs for 7 days, 12 months: No graphs.
Re:Rainfall graphs not working ** solved **
Yes, you are right. removed the "solved" sticker. will be part of the next update, 2.6g.
