[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 5.4.52 (boris@newdevelop) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r14089-1bfba18a36)) #0 SMP Sat Aug 8 08:31:57 2020
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.5
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000002ac00000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] DMA zone: 3792 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 242688 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 21 pages/cpu s45080 r8192 d32744 u86016
[ 0.000000] pcpu-alloc: s45080 r8192 d32744 u86016 alloc=21*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 238896
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=D8:3A:DD:0E:3C:C0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=squashfs,ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 874860K/970752K available (6590K kernel code, 406K rwdata, 1720K rodata, 576K init, 525K bss, 30356K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: CONFIG_RCU_FANOUT set to non-default value of 32.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x2dc/0x3dc with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000153] Console: colour dummy device 80x25
[ 0.000379] printk: console [tty1] enabled
[ 0.000407] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[ 0.000428] pid_max: default: 32768 minimum: 301
[ 0.000572] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.000602] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.001269] Disabling memory control group subsystem
[ 0.002012] ASID allocator initialised with 32768 entries
[ 0.002101] rcu: Hierarchical SRCU implementation.
[ 0.002712] smp: Bringing up secondary CPUs ...
[ 0.003109] Detected PIPT I-cache on CPU1
[ 0.003163] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.003613] Detected PIPT I-cache on CPU2
[ 0.003647] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.004153] Detected PIPT I-cache on CPU3
[ 0.004186] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.004254] smp: Brought up 1 node, 4 CPUs
[ 0.004281] SMP: Total of 4 processors activated.
[ 0.004294] CPU features: detected: 32-bit EL0 Support
[ 0.004307] CPU features: detected: CRC32 instructions
[ 0.004357] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.004374] CPU: All CPU(s) started at EL2
[ 0.004402] alternatives: patching kernel code
[ 0.011941] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.012011] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.013659] pinctrl core: initialized pinctrl subsystem
[ 0.014416] NET: Registered protocol family 16
[ 0.016066] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.016407] cpuidle: using governor ladder
[ 0.016436] cpuidle: using governor menu
[ 0.016706] Serial: AMBA PL011 UART driver
[ 0.018146] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.028046] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-02-01 13:20, variant start
[ 0.032049] raspberrypi-firmware soc:firmware: Firmware hash is 2a652e2a1ddcf0f358bc6278802ff7d8f1397c2e
[ 0.056538] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.058209] SCSI subsystem initialized
[ 0.058357] usbcore: registered new interface driver usbfs
[ 0.058397] usbcore: registered new interface driver hub
[ 0.058455] usbcore: registered new device driver usb
[ 0.059354] clocksource: Switched to clocksource arch_sys_counter
[ 0.062508] thermal_sys: Registered thermal governor 'step_wise'
[ 0.062741] NET: Registered protocol family 2
[ 0.063194] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 0.063227] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.063302] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.063455] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.063638] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.063668] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.063827] NET: Registered protocol family 1
[ 0.063860] PCI: CLS 0 bytes, default 64
[ 0.065196] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 0.069439] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.094935] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.094964] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 0.095002] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
[ 0.095036] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x003fffffff -> 0x0400000000
[ 0.161422] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
[ 0.161576] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.161596] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.161614] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.161655] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.161743] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.164837] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.164992] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.165078] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.165246] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.168283] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.168320] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.168340] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.168399] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.168414] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.168557] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 0.168694] pcieport 0000:00:00.0: PME: Signaling with IRQ 38
[ 0.168913] pcieport 0000:00:00.0: AER: enabled with IRQ 38
[ 0.169081] pci 0000:01:00.0: enabling device (0000 -> 0002)
[ 0.215542] pci 0000:01:00.0: quirk_usb_early_handoff+0x0/0x888 took 45385 usecs
[ 0.215772] bcm2708_fb soc:fb: Unable to determine number of FBs. Disabling driver.
[ 0.215798] bcm2708_fb: probe of soc:fb failed with error -2
[ 0.216602] raspberrypi-clk firmware-clocks: CPU frequency range: min 600000000, max 1500000000
[ 0.217839] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.218555] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.218916] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.219126] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.225234] brd: module loaded
[ 0.228383] loop: module loaded
[ 0.229901] libphy: Fixed MDIO Bus: probed
[ 0.230145] bcmgenet fd580000.ethernet: failed to get enet clock
[ 0.230166] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 0.230183] bcmgenet fd580000.ethernet: failed to get enet-wol clock
[ 0.230199] bcmgenet fd580000.ethernet: failed to get enet-eee clock
[ 0.230223] bcmgenet: Skipping UMAC reset
[ 0.239362] libphy: bcmgenet MII bus: probed
[ 0.287397] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 0.288257] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.288288] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.288796] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 0.289444] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 0.289465] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.289482] usb usb1: Product: xHCI Host Controller
[ 0.289495] usb usb1: Manufacturer: Linux 5.4.52 xhci-hcd
[ 0.289509] usb usb1: SerialNumber: 0000:01:00.0
[ 0.289805] hub 1-0:1.0: USB hub found
[ 0.289874] hub 1-0:1.0: 1 port detected
[ 0.290269] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.290290] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.290313] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.290534] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ 0.290554] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.290570] usb usb2: Product: xHCI Host Controller
[ 0.290584] usb usb2: Manufacturer: Linux 5.4.52 xhci-hcd
[ 0.290596] usb usb2: SerialNumber: 0000:01:00.0
[ 0.290869] hub 2-0:1.0: USB hub found
[ 0.290915] hub 2-0:1.0: 4 ports detected
[ 0.291596] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.291684] dwc_otg: FIQ enabled
[ 0.291687] dwc_otg: NAK holdoff enabled
[ 0.291691] dwc_otg: FIQ split-transaction FSM enabled
[ 0.291697] Module dwc_common_port init
[ 0.291948] usbcore: registered new interface driver uas
[ 0.292019] usbcore: registered new interface driver usb-storage
[ 0.292095] mousedev: PS/2 mouse device common for all mice
[ 0.292512] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.293425] sdhci: Secure Digital Host Controller Interface driver
[ 0.293439] sdhci: Copyright(c) Pierre Ossman
[ 0.293704] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.293901] Error: Driver 'sdhost-bcm2835' is already registered, aborting...
[ 0.293915] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.300115] vchiq: vchiq_init_state: slot_zero = (____ptrval____)
[ 0.301600] NET: Registered protocol family 10
[ 0.302025] Segment Routing with IPv6
[ 0.302058] NET: Registered protocol family 17
[ 0.302077] 8021q: 802.1Q VLAN Support v1.8
[ 0.302287] Key type ._fscrypt registered
[ 0.302293] Key type .fscrypt registered
[ 0.305221] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.305271] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 14, base_baud = 0) is a PL011 rev2
[ 0.639348] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 0.647892] printk: console [ttyAMA0] enabled
[ 0.863818] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 0.877700] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.880155] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 0.880158] usb 1-1: Product: USB2.0 Hub
[ 0.885835] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.918683] hub 1-1:1.0: USB hub found
[ 0.925589] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.974284] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.983085] hub 1-1:1.0: 4 ports detected
[ 0.990209] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.364705] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.372678] of_cfs_init
[ 1.375162] of_cfs_init: OK
[ 1.375347] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
[ 1.379754] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.390290] Waiting for root device /dev/mmcblk0p2...
[ 1.397799] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.404755] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.429667] random: fast init done
[ 1.467512] mmc1: new high speed SDIO card at address 0001
[ 1.501491] usb 1-1.4: New USB device found, idVendor=1997, idProduct=2433, bcdDevice= 1.10
[ 1.509864] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.517182] usb 1-1.4: Product: mini keyboard
[ 1.521541] usb 1-1.4: Manufacturer:
[ 1.609031] mmc0: new ultra high speed SDR25 SD card at address 0001
[ 1.616078] mmcblk0: mmc0:0001 N1BM1 1.88 GiB
[ 1.621714] mmcblk0: p1 p2 p3
[ 1.643839] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[ 1.651395] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.658778] Freeing unused kernel memory: 576K
[ 1.663484] Run /sbin/init as init process
[ 1.749181] init: Console is alive
[ 1.752672] init: - watchdog -
[ 1.950391] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 1.962544] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.970248] ehci-fsl: Freescale EHCI Host controller driver
[ 1.976390] ehci-platform: EHCI generic platform driver
[ 1.983796] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.990261] ohci-platform: OHCI generic platform driver
[ 1.996504] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.004207] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 2.018114] init: - preinit -
[ 2.099643] bcmgenet: Skipping UMAC reset
[ 2.104855] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 2.112321] bcmgenet fd580000.ethernet eth0: Link is Down
[ 6.162791] mount_root: mounting /dev/root
[ 6.167298] EXT4-fs (mmcblk0p2): warning: mounting unchecked fs, running e2fsck is recommended
[ 6.182477] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.191052] random: procd: uninitialized urandom read (4 bytes read)
[ 6.208465] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 6.219348] urandom-seed: Seeding with /etc/urandom.seed
[ 6.265404] procd: - early -
[ 6.268382] procd: - watchdog -
[ 6.797991] procd: - watchdog -
[ 6.801358] procd: - ubus -
[ 6.811466] random: ubusd: uninitialized urandom read (4 bytes read)
[ 6.854588] random: ubusd: uninitialized urandom read (4 bytes read)
[ 6.861781] procd: - init -
[ 6.868238] uart-pl011 fe201000.serial: no DMA platform data
[ 6.989832] kmodloader: loading kernel modules from /etc/modules.d/*
[ 6.995067] urngd: v1.0.2 started.
[ 7.016159] random: crng init done
[ 7.019586] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.026320] hidraw: raw HID events driver (C) Jiri Kosina
[ 7.032595] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.051587] Loading modules backported from Linux version v5.8-rc2-0-g48778464bb7d
[ 7.059169] Backport generated by backports.git v5.8-rc2-1-0-g7a69429b
[ 7.073574] input: mini keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:1997:2433.0001/input/input0
[ 7.147423] hid-generic 0003:1997:2433.0001: input,hidraw0: USB HID v1.01 Keyboard [ mini keyboard] on usb-0000:01:00.0-1.4/input0
[ 7.164210] input: mini keyboard Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0002/input/input1
[ 7.180003] input: mini keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0002/input/input2
[ 7.255644] input: mini keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0002/input/input3
[ 7.272280] hid-generic 0003:1997:2433.0002: input,hidraw1: USB HID v1.01 Mouse [ mini keyboard] on usb-0000:01:00.0-1.4/input1
[ 7.283935] usbcore: registered new interface driver usbhid
[ 7.289517] usbhid: USB HID core driver
[ 7.294859] usbcore: registered new interface driver usbserial_generic
[ 7.301479] usbserial: USB Serial support registered for generic
[ 7.309265] xt_time: kernel timezone is -0000
[ 7.331689] usbcore: registered new interface driver ch341
[ 7.337217] usbserial: USB Serial support registered for ch341-uart
[ 7.344102] usbcore: registered new interface driver cp210x
[ 7.349708] usbserial: USB Serial support registered for cp210x
[ 7.356245] usbcore: registered new interface driver ftdi_sio
[ 7.362014] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 7.374194] usbcore: registered new interface driver pl2303
[ 7.379820] usbserial: USB Serial support registered for pl2303
[ 7.386846] PPP generic driver version 2.4.2
[ 7.391558] NET: Registered protocol family 24
[ 7.416056] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.425584] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.bin failed with error -2
[ 7.435328] brcmfmac mmc1:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac43455-sdio.bin
[ 12.511674] usbcore: registered new interface driver brcmfmac
[ 12.520469] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 13.535399] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 13.552176] bcmgenet: Skipping UMAC reset
[ 13.557336] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 13.564808] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 13.573396] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 21.726131] start /root/start.sh
[ 26.988131] EXT4-fs (mmcblk0p3): Mount option "data=ordered" incompatible with ext2
[ 27.012533] EXT4-fs (mmcblk0p3): recovery complete
[ 27.017373] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: commit=60,data=ordered,max_batch_time=1000000,min_batch_time=1000000,errors=remount-ro
[ 34.805955] /dev/sda1: Can't open blockdev
[ 34.812540] /dev/sda: Can't open blockdev
[ 34.817980] extract meteobridge archive
[ 35.116355] meteobridge archive extracted
[ 35.123324] done /root/start.sh
[ 35.127759] start /home/setup.sh
[ 35.154128] /dev/sda1: Can't open blockdev
[ 35.251725] usb 1-1.4: reset full-speed USB device number 3 using xhci_hcd
[ 35.370437] usb 1-1.4: USB disconnect, device number 3
[ 35.691688] usb 1-1: reset high-speed USB device number 2 using xhci_hcd
[ 36.147380] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
[ 36.257387] usb 1-1.4: New USB device found, idVendor=1997, idProduct=2433, bcdDevice= 1.10
[ 36.265768] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 36.273102] usb 1-1.4: Product: mini keyboard
[ 36.277472] usb 1-1.4: Manufacturer:
[ 36.288994] input: mini keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:1997:2433.0003/input/input4
[ 36.363622] hid-generic 0003:1997:2433.0003: input,hidraw0: USB HID v1.01 Keyboard [ mini keyboard] on usb-0000:01:00.0-1.4/input0
[ 36.381335] input: mini keyboard Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0004/input/input5
[ 36.397079] input: mini keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0004/input/input6
[ 36.471713] input: mini keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0004/input/input7
[ 36.488377] hid-generic 0003:1997:2433.0004: input,hidraw1: USB HID v1.01 Mouse [ mini keyboard] on usb-0000:01:00.0-1.4/input1
[ 36.689592] EXT4-fs (mmcblk0p3): re-mounted. Opts: errors=remount-ro,commit=60,min_batch_time=1000000,max_batch_time=1000000,stripe=2,data=ordered
[ 50.643808] done /home/setup.sh
[ 50.664574] --------
[ 50.666812] Meteobridge is a headless device. Please direct your browser to 192.168.1.125 in order to interact with the GUI.
