Cannot connect my Rpi to wifi
- wsnoordbergum
Bought a brand new pi 4b with 1Gb of ram
I installed the FW 1.4 on a 2Gb micro SD card, one that has been recommended with Raspberry Pi imager
Installation of meteobridge went fine, on cabled LAN
Change settings to wifi, but it will not connect to my wireless network
It is certainly not a range problem as it is located just a few feet away from the router
So I tried the 1.3 version as suggested, but that does not work at all
I only see the green LED flash 4 times slow the 4 times fast, but nothing happens, and the green LED repeats the sequence the red LED does not blink and will not go into fast blinking showing it is trying to connect and download the stack
Tried different wifi settings but no luck
On an older model the 1.3 version does work, but I have that one running CumulusMX and the 1.4 did not work on that one
I could run on cabled LAN but prefer wireless
Any suggestions?
Any suggestions?
Re: Cannot connect my Rpi to wifi
is your RPi a 1.4 revision model or a 1.5 revision model ?
check with the dmesg command - or with.
It should show something like this (see last line)
If 1.5, try the 1.5 image - see sticky threads
cat /proc/cpuinfoIt should show something like this (see last line)
processor : 0
model name : ARMv7 Processor rev 3 (v7l)
BogoMIPS : 126.00
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 126.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 126.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 126.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2711
Revision : c03114
Serial : 100000005632e773
Model : Raspberry Pi 4 Model B Rev 1.4
- wsnoordbergum
I have rev. 1.5 model
So 1.5 should work?
So 1.5 should work?
- wsnoordbergum
Well first thing that came to mind was that I still had an older version of 1.4 version of meteobridge, downloaded a new one with the 1.5 compatibility, but still it will not connect to my wifi
I have it set the same as my Nano SD network configuration though the Rpi is also capable of 5 gHz wifi
Tried every setting even tried to connect it to my guest network, but it will not connect
So here are my Pi 4b rev 1.5 specs
processor : 0
BogoMIPS : 108.00
Features : fp asimd evtstrm crc32 cpuid
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2835
Revision : a03115
Serial : 1000000070d9ca55
Model : Raspberry Pi 4 Model B Rev 1.5
- wsnoordbergum
dmesg outputs this
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 5.4.52 (boris@newdevelop) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r14089-1bfba18a36)) #0 SMP Sat Aug 8 08:31:57 2020
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.5
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000002ac00000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] DMA zone: 3792 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 242688 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 21 pages/cpu s45080 r8192 d32744 u86016
[ 0.000000] pcpu-alloc: s45080 r8192 d32744 u86016 alloc=21*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 238896
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=D8:3A:DD:0E:3C:C0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=squashfs,ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 874860K/970752K available (6590K kernel code, 406K rwdata, 1720K rodata, 576K init, 525K bss, 30356K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: CONFIG_RCU_FANOUT set to non-default value of 32.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x2dc/0x3dc with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000153] Console: colour dummy device 80x25
[ 0.000379] printk: console [tty1] enabled
[ 0.000407] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[ 0.000428] pid_max: default: 32768 minimum: 301
[ 0.000572] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.000602] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.001269] Disabling memory control group subsystem
[ 0.002012] ASID allocator initialised with 32768 entries
[ 0.002101] rcu: Hierarchical SRCU implementation.
[ 0.002712] smp: Bringing up secondary CPUs ...
[ 0.003109] Detected PIPT I-cache on CPU1
[ 0.003163] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.003613] Detected PIPT I-cache on CPU2
[ 0.003647] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.004153] Detected PIPT I-cache on CPU3
[ 0.004186] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.004254] smp: Brought up 1 node, 4 CPUs
[ 0.004281] SMP: Total of 4 processors activated.
[ 0.004294] CPU features: detected: 32-bit EL0 Support
[ 0.004307] CPU features: detected: CRC32 instructions
[ 0.004357] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.004374] CPU: All CPU(s) started at EL2
[ 0.004402] alternatives: patching kernel code
[ 0.011941] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.012011] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.013659] pinctrl core: initialized pinctrl subsystem
[ 0.014416] NET: Registered protocol family 16
[ 0.016066] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.016407] cpuidle: using governor ladder
[ 0.016436] cpuidle: using governor menu
[ 0.016706] Serial: AMBA PL011 UART driver
[ 0.018146] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.028046] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-02-01 13:20, variant start
[ 0.032049] raspberrypi-firmware soc:firmware: Firmware hash is 2a652e2a1ddcf0f358bc6278802ff7d8f1397c2e
[ 0.056538] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.058209] SCSI subsystem initialized
[ 0.058357] usbcore: registered new interface driver usbfs
[ 0.058397] usbcore: registered new interface driver hub
[ 0.058455] usbcore: registered new device driver usb
[ 0.059354] clocksource: Switched to clocksource arch_sys_counter
[ 0.062508] thermal_sys: Registered thermal governor 'step_wise'
[ 0.062741] NET: Registered protocol family 2
[ 0.063194] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 0.063227] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.063302] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.063455] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.063638] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.063668] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.063827] NET: Registered protocol family 1
[ 0.063860] PCI: CLS 0 bytes, default 64
[ 0.065196] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 0.069439] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.094935] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.094964] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 0.095002] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
[ 0.095036] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x003fffffff -> 0x0400000000
[ 0.161422] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
[ 0.161576] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.161596] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.161614] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.161655] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.161743] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.164837] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.164992] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.165078] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.165246] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.168283] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.168320] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.168340] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.168399] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.168414] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.168557] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 0.168694] pcieport 0000:00:00.0: PME: Signaling with IRQ 38
[ 0.168913] pcieport 0000:00:00.0: AER: enabled with IRQ 38
[ 0.169081] pci 0000:01:00.0: enabling device (0000 -> 0002)
[ 0.215542] pci 0000:01:00.0: quirk_usb_early_handoff+0x0/0x888 took 45385 usecs
[ 0.215772] bcm2708_fb soc:fb: Unable to determine number of FBs. Disabling driver.
[ 0.215798] bcm2708_fb: probe of soc:fb failed with error -2
[ 0.216602] raspberrypi-clk firmware-clocks: CPU frequency range: min 600000000, max 1500000000
[ 0.217839] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.218555] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.218916] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.219126] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.225234] brd: module loaded
[ 0.228383] loop: module loaded
[ 0.229901] libphy: Fixed MDIO Bus: probed
[ 0.230145] bcmgenet fd580000.ethernet: failed to get enet clock
[ 0.230166] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 0.230183] bcmgenet fd580000.ethernet: failed to get enet-wol clock
[ 0.230199] bcmgenet fd580000.ethernet: failed to get enet-eee clock
[ 0.230223] bcmgenet: Skipping UMAC reset
[ 0.239362] libphy: bcmgenet MII bus: probed
[ 0.287397] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 0.288257] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.288288] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.288796] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 0.289444] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 0.289465] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.289482] usb usb1: Product: xHCI Host Controller
[ 0.289495] usb usb1: Manufacturer: Linux 5.4.52 xhci-hcd
[ 0.289509] usb usb1: SerialNumber: 0000:01:00.0
[ 0.289805] hub 1-0:1.0: USB hub found
[ 0.289874] hub 1-0:1.0: 1 port detected
[ 0.290269] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.290290] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.290313] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.290534] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ 0.290554] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.290570] usb usb2: Product: xHCI Host Controller
[ 0.290584] usb usb2: Manufacturer: Linux 5.4.52 xhci-hcd
[ 0.290596] usb usb2: SerialNumber: 0000:01:00.0
[ 0.290869] hub 2-0:1.0: USB hub found
[ 0.290915] hub 2-0:1.0: 4 ports detected
[ 0.291596] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.291684] dwc_otg: FIQ enabled
[ 0.291687] dwc_otg: NAK holdoff enabled
[ 0.291691] dwc_otg: FIQ split-transaction FSM enabled
[ 0.291697] Module dwc_common_port init
[ 0.291948] usbcore: registered new interface driver uas
[ 0.292019] usbcore: registered new interface driver usb-storage
[ 0.292095] mousedev: PS/2 mouse device common for all mice
[ 0.292512] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.293425] sdhci: Secure Digital Host Controller Interface driver
[ 0.293439] sdhci: Copyright(c) Pierre Ossman
[ 0.293704] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.293901] Error: Driver 'sdhost-bcm2835' is already registered, aborting...
[ 0.293915] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.300115] vchiq: vchiq_init_state: slot_zero = (____ptrval____)
[ 0.301600] NET: Registered protocol family 10
[ 0.302025] Segment Routing with IPv6
[ 0.302058] NET: Registered protocol family 17
[ 0.302077] 8021q: 802.1Q VLAN Support v1.8
[ 0.302287] Key type ._fscrypt registered
[ 0.302293] Key type .fscrypt registered
[ 0.305221] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.305271] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 14, base_baud = 0) is a PL011 rev2
[ 0.639348] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 0.647892] printk: console [ttyAMA0] enabled
[ 0.863818] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 0.877700] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.880155] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 0.880158] usb 1-1: Product: USB2.0 Hub
[ 0.885835] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.918683] hub 1-1:1.0: USB hub found
[ 0.925589] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.974284] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.983085] hub 1-1:1.0: 4 ports detected
[ 0.990209] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.364705] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.372678] of_cfs_init
[ 1.375162] of_cfs_init: OK
[ 1.375347] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
[ 1.379754] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.390290] Waiting for root device /dev/mmcblk0p2...
[ 1.397799] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.404755] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.429667] random: fast init done
[ 1.467512] mmc1: new high speed SDIO card at address 0001
[ 1.501491] usb 1-1.4: New USB device found, idVendor=1997, idProduct=2433, bcdDevice= 1.10
[ 1.509864] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.517182] usb 1-1.4: Product: mini keyboard
[ 1.521541] usb 1-1.4: Manufacturer:
[ 1.609031] mmc0: new ultra high speed SDR25 SD card at address 0001
[ 1.616078] mmcblk0: mmc0:0001 N1BM1 1.88 GiB
[ 1.621714] mmcblk0: p1 p2 p3
[ 1.643839] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[ 1.651395] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.658778] Freeing unused kernel memory: 576K
[ 1.663484] Run /sbin/init as init process
[ 1.749181] init: Console is alive
[ 1.752672] init: - watchdog -
[ 1.950391] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 1.962544] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.970248] ehci-fsl: Freescale EHCI Host controller driver
[ 1.976390] ehci-platform: EHCI generic platform driver
[ 1.983796] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.990261] ohci-platform: OHCI generic platform driver
[ 1.996504] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.004207] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 2.018114] init: - preinit -
[ 2.099643] bcmgenet: Skipping UMAC reset
[ 2.104855] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 2.112321] bcmgenet fd580000.ethernet eth0: Link is Down
[ 6.162791] mount_root: mounting /dev/root
[ 6.167298] EXT4-fs (mmcblk0p2): warning: mounting unchecked fs, running e2fsck is recommended
[ 6.182477] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.191052] random: procd: uninitialized urandom read (4 bytes read)
[ 6.208465] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 6.219348] urandom-seed: Seeding with /etc/urandom.seed
[ 6.265404] procd: - early -
[ 6.268382] procd: - watchdog -
[ 6.797991] procd: - watchdog -
[ 6.801358] procd: - ubus -
[ 6.811466] random: ubusd: uninitialized urandom read (4 bytes read)
[ 6.854588] random: ubusd: uninitialized urandom read (4 bytes read)
[ 6.861781] procd: - init -
[ 6.868238] uart-pl011 fe201000.serial: no DMA platform data
[ 6.989832] kmodloader: loading kernel modules from /etc/modules.d/*
[ 6.995067] urngd: v1.0.2 started.
[ 7.016159] random: crng init done
[ 7.019586] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.026320] hidraw: raw HID events driver (C) Jiri Kosina
[ 7.032595] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.051587] Loading modules backported from Linux version v5.8-rc2-0-g48778464bb7d
[ 7.059169] Backport generated by backports.git v5.8-rc2-1-0-g7a69429b
[ 7.073574] input: mini keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:1997:2433.0001/input/input0
[ 7.147423] hid-generic 0003:1997:2433.0001: input,hidraw0: USB HID v1.01 Keyboard [ mini keyboard] on usb-0000:01:00.0-1.4/input0
[ 7.164210] input: mini keyboard Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0002/input/input1
[ 7.180003] input: mini keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0002/input/input2
[ 7.255644] input: mini keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0002/input/input3
[ 7.272280] hid-generic 0003:1997:2433.0002: input,hidraw1: USB HID v1.01 Mouse [ mini keyboard] on usb-0000:01:00.0-1.4/input1
[ 7.283935] usbcore: registered new interface driver usbhid
[ 7.289517] usbhid: USB HID core driver
[ 7.294859] usbcore: registered new interface driver usbserial_generic
[ 7.301479] usbserial: USB Serial support registered for generic
[ 7.309265] xt_time: kernel timezone is -0000
[ 7.331689] usbcore: registered new interface driver ch341
[ 7.337217] usbserial: USB Serial support registered for ch341-uart
[ 7.344102] usbcore: registered new interface driver cp210x
[ 7.349708] usbserial: USB Serial support registered for cp210x
[ 7.356245] usbcore: registered new interface driver ftdi_sio
[ 7.362014] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 7.374194] usbcore: registered new interface driver pl2303
[ 7.379820] usbserial: USB Serial support registered for pl2303
[ 7.386846] PPP generic driver version 2.4.2
[ 7.391558] NET: Registered protocol family 24
[ 7.416056] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.425584] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.bin failed with error -2
[ 7.435328] brcmfmac mmc1:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac43455-sdio.bin
[ 12.511674] usbcore: registered new interface driver brcmfmac
[ 12.520469] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 13.535399] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 13.552176] bcmgenet: Skipping UMAC reset
[ 13.557336] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 13.564808] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 13.573396] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 21.726131] start /root/start.sh
[ 26.988131] EXT4-fs (mmcblk0p3): Mount option "data=ordered" incompatible with ext2
[ 27.012533] EXT4-fs (mmcblk0p3): recovery complete
[ 27.017373] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: commit=60,data=ordered,max_batch_time=1000000,min_batch_time=1000000,errors=remount-ro
[ 34.805955] /dev/sda1: Can't open blockdev
[ 34.812540] /dev/sda: Can't open blockdev
[ 34.817980] extract meteobridge archive
[ 35.116355] meteobridge archive extracted
[ 35.123324] done /root/start.sh
[ 35.127759] start /home/setup.sh
[ 35.154128] /dev/sda1: Can't open blockdev
[ 35.251725] usb 1-1.4: reset full-speed USB device number 3 using xhci_hcd
[ 35.370437] usb 1-1.4: USB disconnect, device number 3
[ 35.691688] usb 1-1: reset high-speed USB device number 2 using xhci_hcd
[ 36.147380] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
[ 36.257387] usb 1-1.4: New USB device found, idVendor=1997, idProduct=2433, bcdDevice= 1.10
[ 36.265768] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 36.273102] usb 1-1.4: Product: mini keyboard
[ 36.277472] usb 1-1.4: Manufacturer:
[ 36.288994] input: mini keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:1997:2433.0003/input/input4
[ 36.363622] hid-generic 0003:1997:2433.0003: input,hidraw0: USB HID v1.01 Keyboard [ mini keyboard] on usb-0000:01:00.0-1.4/input0
[ 36.381335] input: mini keyboard Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0004/input/input5
[ 36.397079] input: mini keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0004/input/input6
[ 36.471713] input: mini keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0004/input/input7
[ 36.488377] hid-generic 0003:1997:2433.0004: input,hidraw1: USB HID v1.01 Mouse [ mini keyboard] on usb-0000:01:00.0-1.4/input1
[ 36.689592] EXT4-fs (mmcblk0p3): re-mounted. Opts: errors=remount-ro,commit=60,min_batch_time=1000000,max_batch_time=1000000,stripe=2,data=ordered
[ 50.643808] done /home/setup.sh
[ 50.664574] --------
[ 50.666812] Meteobridge is a headless device. Please direct your browser to 192.168.1.125 in order to interact with the GUI.Re: Cannot connect my Rpi to wifi
two things - for the WLAN connection it is not important that the hardware in principle supports a 5 GHz wireless network - the installed OS (openWRT) needs to support it
you could try a 2.4 GHz connection
your dmsg output shows only the eth0 (= LAN) interface to be connected/activated by the OS - no WLAN interface (wlan0 should be found)
maybe having a look at
https://openwrt.org/toh/raspberry_pi_fo ... spberry_pi
could give some more insights
Meteobridge on RPI does not support MESH networks or any boost options. It needs to be good old plain 2.4 (ng) or 5 GHz (a) and WPA2.
- AlphaXrayPapa
- Fresh Boarder
I appear to be having this exact same issue and the suggestions within this thread thus far have not proved helpful.
I too tried the v1.3 firmware and the RPi clearly says this is not compatible.
There needs to be a v1.5 to support these, apparently, slightly newer boards, that or some work around that can be provided to users who've paid for a license.
If this cannot be made to work with an RPi4, then how does one go about obtaining a refund?
- AlphaXrayPapa
- Fresh Boarder
I happened to have an older RPi 4 on hand, it's a v1.2 board. The problem with the v1.4 firmware is the same and the v1.3 won't boot at all.
