Meteobridge Nano SD
sebastian
Meteobridge Nano SD
Post by sebastian »
Hi there,
I'm new to the Meteobridge world, so still learning how things work. We recently purchased a MB Nano SD and I just started setting everything up with a Davis Vantage Pro2 console. I managed to give the NanoSD a fixed IP address and connect it to our network. The NanoSD runs Meteobridge 5.7 which I think is the latest version.
The problem I am having is that after a couple of minutes the meteobridge hotspot disappears from my list of visible networks and I can't reach it any more. The Nano's red light is solid. It comes back when I unplug the console power and plug it back in. I there a way to tell the Nano to keep the hotspot on permanently? This is also important for us because we will be deploying the weather station in a remote region where there is no wifi or mobile data available. So we will have to connect to it via the meteobridge hotspot.
Thanks for the help,
Sebastian
Re: Meteobridge Nano SD
The NANO provides a WiFi Access Point for initial setup to a WiFi Client with the AP shut down after a short period for security purposes. The WiFi Access Point does have a Stand-Alone radio-button option under the Network Tab.
Check this page https://www.meteobridge.com/wiki/index.php/Forum for version released February 22, 2023
sebastian
Post by sebastian »
Thanks, Mattk. That worked perfectly. Exactly what I was looking for.
Best wishes,
Sebastian
