Trouble Deleting Data from Mapped Sensors
hymrog
Post by hymrog »
Hi -
Trying to delete the max reading for two sensors that I have mapped to the following:
t0!0temp soil0temp soil temperature #0
t0!2temp soil2temp soil temperature #2
I have edited/deleted the hourly data for t0!temp and t0!2temp but the max data information is still being reported on the Min/Max Data tab even though the "Edit Hour Data" is reflecting the correct information.
Also as part of the process I have clicked the Database Reconstruct button.
Currently running the following
Platform: Raspberry Pi 3 Model B+
RAM: 941 MB total, 751 MB free (20% used)
Storage: WD SLC, 29.3 GB total, 26.8 GB free (9% used, 3135.9 yrs)
SW Version: Meteobridge 5.6 (Apr 6 2023, build 2730), FW 1.3
Uptime: 7 days, 2 hours, 53 minutes Buffer: 1 items (0%)
Edit: I seemed to have resolved the issue with a reboot of the system…Not 100% sure if this is normal activity to correct the mapped sensors data. If I recall correctly you can simply make the corrections as normal for the non-mapped sensors and the correction sticks without the reboot.
g
Re: Trouble Deleting Data from Mapped Sensors
I think there are still occurrences of the unwanted data in your database. Please examine with a graph at which points in time to look in your database. If the graphs does not show the extremes either, I will have to inspect your database, but I don't think there is an internal error (as you already did the reconstruct).
