hello
impossible to run "Meteobridge Chart Generator" correctly on a device
MB Pro RED 5.7 (Jul 31 2023, build 15012), FW 1.4
is this your case ?
Thank you and good day
Bug in the display of "Meta Charts"?
meteolive57290
- Senior Boarder
Re: Bug in the display of "Meta Charts"?
can you give examples what does not work correctly ?
e.g.
- cannot enter the menu point/page ?
- cannot choose a (which?) sensor
- sensor is not drawn
- cannot save chart
etc.
With this description of yours we have no idea what you mean exactly ....
e.g.
- cannot save chart
etc.
meteolive57290
- Senior Boarder
hmm
simply when you go through the "Generate" feature and want to choose a default template nothing is generated in the window and therefore "when you want the remote link the page is blank!?
https://admin.meteobridge.com/5c81a2314 ... D2&stop=D1
it's the same thing locally .... on the other hand if I choose a "custom" template in this case it works correctly ....
- Capture d'écran 2023-08-05 083337.png (37.21 KiB) Viewed 5989 times
with me it works - Meteobridge 5.7 (Jul 31 2023, build 15012), FW 1.4
(also with yesterday, 10 minutes, allinone-iso)
- MB-5.7-isochart_20230803.jpg (170.55 KiB) Viewed 5988 times
meteolive57290
- Senior Boarder
Same as Gyvate, same firmware, don't see any chart issues, generates that identical chart no problems.
may be a browser cache issue? Did you try a browser restart?
meteolive57290
- Senior Boarder
Mozilla updated cache yes emptied and restarting the browser too... the charts don't show up if I choose any template with the MB and naturally the remote link still shows me a blank page...
Tried your remote link again and it looks fine. Must be something on your client side.
