Changing templates on a black Pro2
bpweather
Post by bpweather »
I had a Pro which died, so I recently upgraded to a Pro2. With my Pro, a directory was created on my MacPro which held all the templates so once I figured out how to use them, to load my own, I could just overwrite an existing or add another to the directory.
But since adding the Pro2, no directories have been created (not even the /data/templates that is the standard?).
I had made new templates for the display and for the email events and they worked fine on the Pro.
I still have copies of my old templates but I have not figured out how to load them into the Pro2. I tried sending the sample http which was to supposed to send back the date/time , temp and humidity, but I just get the share data/templates does not exist.
If anyone could help me out as to what I am doing wrong, or what I should be doing to be able to use my own templates , I would be extremely grateful for your time and assistance.
Re: Changing templates on a black Pro2
SMB security on the PRO2 is different to the PRO and dependent on the OS connected. Have no experience with Mac but with Windows there is a difference depending on the setup.
Have you setup or changed the SMB password and/or what SMB control do you have set, such as SMB User only, SMB Guests allowed or SMB Disabled etc
bpweather
Post by bpweather »
Haven't changed anything since the Pro, but lookin it up on the mac, SMB was off (it was off with the PRO too)
I changed File sharing to ON , SMB to ON, guests allowed and gave full access to a new directory I made called Data.
I don't know if I need to create a User account, for the Pro I didn't do anything at all, it just showed up. I'm not sure what the "User" would be
for the Pro2 unless its meteobridge.
Thanks for your time and help. I really appreciate it.
User is typically meteobridge and initially password is meteobridge. As mentioned not a MAC person, how do you access the SMB share on a MAC as opposed to Windows \\your.ip.address.here\data
Pro & Pro2 are no different apart from changed security with both having a pop up User/Password screen when SMB User only is set
What do you get running http://ip-of-your-meteobridge/upload.html
