MB Pro2 Scheduled Data Export: month in minute resolution
sebastian
Post by sebastian »
Hi there,
I ran into a an issue on my MB Pro2. I am trying to schedule a monthly data export in 1-minute resolution under Services --> Events. When I add a Data Export event with the following settings
Data Export: after each new month
Time Frame: Previous Month
Resolution: Minutes
Template: custome_template
I get the following error message after saving the settings:
Error (Event #03): Export of a month's data in minute resolution is not supported
The documentation seems to suggest that only the combination year and minute is not possible because file size gets too big. From the documentation:
"All combinations of time frames and resolution are allowed. Only exception is the combination "year - minute" which cannot be selected as it would result into a too large export file."
I think, a month worth of data in minute resolution should be fine. Especially, when an triggered follow-up event pushes exported file to a server and deletes the local copy on the MB.
Any help would be much appreciated.
SW Version: Meteobridge 5.7 (Aug 11 2023, build 4133), FW 1.3
Many thanks,
Sebastian
Re: MB Pro2 Scheduled Data Export: month in minute resolution
What is Per-Minute Data Time Resolution settings? Database>Administration
sebastian
Post by sebastian »
I don't think I changed any of that. Time Resolution Per-Minute Data is set to no persistent storage and no automated deletion.
Sebastian
WetterCH
Post by WetterCH »
you have to set that the minutely data is saved, otherwise it will only be saved for 24 hours.
this is why there is an error because the minutes data is missing.
sebastian
Post by sebastian »
Thanks WetterCH, I'll give that a go.
