Graphs on NanoSD Query
G4MHJ
Post by G4MHJ »
I have just started to 'play' with the graphs but have an initial query if this could be answered.
Using the Graphs Tab/Generate Chart I am able to display a graph. I can click on the Local Chart URL link and get a result but when I try this using the Remote Chart URL I get the Black screen with the Ooops - Remote access to your Meteobridge is currently not available. Please try later
and/or reboot your device.
What is needed to correct this or is it normal with the nanoSD in a Vantage Pro2 Console.
G4MHJ
Re: Graphs on NanoSD Query
Post by G4MHJ »
I have just found this text on a Graphs - How to:
Meteobridge does also provide you a URL you can use locally or from the internet (when remote login is enabled) to generate the chart.
So, my question is where do I enable remote login?
In System/Adminstration I have ticked the box "Internet Remote Login".
Yep tick the box Allow [Login from the internet]
local chart URL will give a URL beginning with the Nana IP, remote chart URL will give a URL beginning admin.meteobridge.com/xxxxxxxxxxxxxxxxxx
I have no problem with this in a VP2 (Envoy)
G4MHJ
Post by G4MHJ »
Thanks for confirming that only a 'Tick' was necessary. However I had the tick and I had recently done a reboot for other reasons
I decided to remove the 'tick' and reboot again. I then added the tick and rebooted and this time the remote feature worked.
It takes a moment after reboot until the Meteobridge sets up the remote access.
