where to find the wet bulb temperature. **solved**
alexvanuxem
Post by alexvanuxem »
I integrated meteobridge in my home assistant app, through a repository in hacs.
I noticed that one of the entities available is the wet bulb temperature.
but in the MT live data I don't see it listed.
which sensor would it be and how to map?
Grtz
Alex
Re: where to find the wet bulb temperature
Meteobridge does not provide wet bulb temperature. Wet bulb is anyway some artificial data derived from true measured data.
jasonmfarrow
Post by jasonmfarrow »
In the UK Met Office a traditional wet bulb thermometer, housed within a Stevenson Screen, is used to calcaulate the humidity and dew point. https://www.metoffice.gov.uk/weather/le ... /measuring
In most of our modern electronic weather stations the amount of water vapour in the air is directly measured using capacitive sensors but you can reverse calculate the wet bulb temperature if you want.
https://www.omnicalculator.com/physics/wet-bulb , as an example, gives you some explanation and the calculation.
Jason
Wet-bulb temperature has been added to Meteobridge update from October 17, 2023.
