Meteobridge offline. **solved**
norvegese
Post by norvegese »
I rebooted the meteobridge on raspberry
and now it's offline
this writing comes out :
Meteobridge Landing Page (FW 1.3)
You got here, because Meteobridge application stack you wanted to access could not be loaded from the Internet. Most common reason for that is a bad network configuration of the Meteobridge device, that keeps the unit in endless fast blinking LED mode. From here you can do one of the following:
Wait: May be Meteobridge is still in the process of loading application stack from the Internet and it just needs a bit more time. You can give it a second try by this link
Cloud Simulator: You can setup a new network configuration for your device via this configurator in the cloud. You find details how to use this servive in the Meteobridge wiki, here.
Back to Defaults: When you have your Meteobridge in a cabled LAN environent with a DHCP server (mostly the router) up and running, you might be able to solve your networking issue by bringing your device back to standard network setup, by pressing the button until LED lights up for the first time. Unit will reboot in standard LAN DHCP client mode.
OpenWrt: As OpenWrt is fully operational in your device's flash storage and does not need to load an application stack from the Internet, you can start OpenWrt operation by this link. As OpenWrt is a very complex router setup, this is only recommended for experts, who are familar with OpenWrt and might be able to solve networking issues on that level.
To give you insight what your current networking setup is, you'll find some more networking details below. If you are not that deep into networking, just ignore.
IFCONFIG:
eth0 Link encap:Ethernet HWaddr E4:5F:01:15:47:23
inet addr:192.168.168.1 Bcast:192.168.168.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:11 errors:0 dropped:0 overruns:0 frame:0
TX packets:11 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1817 (1.7 KiB) TX bytes:1817 (1.7 KiB)
wlan0 Link encap:Ethernet HWaddr E4:5F:01:15:47:26
inet addr:192.168.178.30 Bcast:192.168.178.255 Mask:255.255.255.0
inet6 addr: fe80::e65f:1ff:fe15:4726/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:8249 errors:0 dropped:2220 overruns:0 frame:0
TX packets:1636 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:5102642 (4.8 MiB) TX bytes:182137 (177.8 KiB)
RESOLV.CONF:
# Interface wlan
nameserver 192.168.178.1
search fritz.box
ROUTE:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.178.1 0.0.0.0 UG 0 0 0 wlan0
192.168.168.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.178.0 0.0.0.0 255.255.255.0 U 0 0 0 wlan0
NSLOOKUP:
Server: 192.168.178.1
Address: 192.168.178.1#53
connect.meteobridge.com canonical name = tau.meteobridge.com
Address 1: 162.55.245.30
Address 2: 2a01:4f8:272:5216::4711
IMAGE LOAD PROTOCOL:
--2023-10-29 11:27:29-- http://download.meteobridge.com/cgi-bin ... AmIaGkIjCh
Resolving download.meteobridge.com... 162.55.245.30, 2a01:4f8:272:5216::4711
Connecting to download.meteobridge.com|162.55.245.30|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 4399753 (4.2M) [application/octet-stream]
Saving to: '/tmp/image.tgz'
0K .......... .......... .......... .......... .......... 1% 1.02M 4s
50K .......... .......... .......... .......... .......... 2% 2.21M 3s
100K .......... .......... .......... .......... .......... 3% 4.84M 2s
150K .......... .......... .......... .......... .......... 4% 5.42M 2s
200K .......... .......... .......... .......... .......... 5% 3.50M 2s
250K .......... .......... .......... .......... .......... 6% 6.63M 1s
300K .......... .......... .......... .......... .......... 8% 7.40M 1s
350K .......... .......... .......... .......... .......... 9% 6.08M 1s
400K .......... .......... .......... .......... .......... 10% 3.17M 1s
450K .......... .......... .......... .......... .......... 11% 6.08M 1s
500K .......... .......... .......... .......... .......... 12% 7.11M 1s
550K .......... .......... .......... .......... .......... 13% 6.06M 1s
600K .......... .......... .......... .......... .......... 15% 2.41M 1s
650K .......... .......... .......... .......... .......... 16% 6.13M 1s
700K .......... .......... .......... .......... .......... 17% 7.02M 1s
750K .......... .......... .......... .......... .......... 18% 7.96M 1s
800K .......... .......... .......... .......... .......... 19% 3.53M 1s
850K .......... .......... .......... .......... .......... 20% 6.94M 1s
900K .......... .......... .......... .......... .......... 22% 6.91M 1s
950K .......... .......... .......... .......... .......... 23% 6.76M 1s
1000K .......... .......... .......... .......... .......... 24% 2.88M 1s
1050K .......... .......... .......... .......... .......... 25% 5.38M 1s
1100K .......... .......... .......... .......... .......... 26% 8.23M 1s
1150K .......... .......... .......... .......... .......... 27% 6.05M 1s
1200K .......... .......... .......... .......... .......... 29% 6.32M 1s
1250K .......... .......... .......... .......... .......... 30% 3.98M 1s
1300K .......... .......... .......... .......... .......... 31% 6.88M 1s
1350K .......... .......... .......... .......... .......... 32% 6.30M 1s
1400K .......... .......... .......... .......... .......... 33% 4.84M 1s
1450K .......... .......... .......... .......... .......... 34% 6.15M 1s
1500K .......... .......... .......... .......... .......... 36% 4.68M 1s
1550K .......... .......... .......... .......... .......... 37% 4.20M 1s
1600K .......... .......... .......... .......... .......... 38% 3.97M 1s
1650K .......... .......... .......... .......... .......... 39% 7.75M 1s
1700K .......... .......... .......... .......... .......... 40% 6.25M 1s
1750K .......... .......... .......... .......... .......... 41% 7.04M 1s
1800K .......... .......... .......... .......... .......... 43% 6.03M 1s
1850K .......... .......... .......... .......... .......... 44% 6.02M 1s
1900K .......... .......... .......... .......... .......... 45% 7.07M 0s
1950K .......... .......... .......... .......... .......... 46% 6.20M 0s
2000K .......... .......... .......... .......... .......... 47% 6.04M 0s
2050K .......... .......... .......... .......... .......... 48% 5.91M 0s
2100K .......... .......... .......... .......... .......... 50% 6.90M 0s
2150K .......... .......... .......... .......... .......... 51% 6.71M 0s
2200K .......... .......... .......... .......... .......... 52% 6.43M 0s
2250K .......... .......... .......... .......... .......... 53% 4.86M 0s
2300K .......... .......... .......... .......... .......... 54% 5.41M 0s
2350K .......... .......... .......... .......... .......... 55% 6.84M 0s
2400K .......... .......... .......... .......... .......... 57% 6.99M 0s
2450K .......... .......... .......... .......... .......... 58% 6.19M 0s
2500K .......... .......... .......... .......... .......... 59% 6.90M 0s
2550K .......... .......... .......... .......... .......... 60% 5.94M 0s
2600K .......... .......... .......... .......... .......... 61% 6.11M 0s
2650K .......... .......... .......... .......... .......... 62% 7.18M 0s
2700K .......... .......... .......... .......... .......... 64% 6.91M 0s
2750K .......... .......... .......... .......... .......... 65% 6.18M 0s
2800K .......... .......... .......... .......... .......... 66% 5.96M 0s
2850K .......... .......... .......... .......... .......... 67% 4.50M 0s
2900K .......... .......... .......... .......... .......... 68% 6.05M 0s
2950K .......... .......... .......... .......... .......... 69% 6.65M 0s
3000K .......... .......... .......... .......... .......... 70% 6.29M 0s
3050K .......... .......... .......... .......... .......... 72% 7.85M 0s
3100K .......... .......... .......... .......... .......... 73% 4.09M 0s
3150K .......... .......... .......... .......... .......... 74% 6.93M 0s
3200K .......... .......... .......... .......... .......... 75% 8.12M 0s
3250K .......... .......... .......... .......... .......... 76% 6.02M 0s
3300K .......... .......... .......... .......... .......... 77% 6.01M 0s
3350K .......... .......... .......... .......... .......... 79% 6.86M 0s
3400K .......... .......... .......... .......... .......... 80% 7.36M 0s
3450K .......... .......... .......... .......... .......... 81% 6.85M 0s
3500K .......... .......... .......... .......... .......... 82% 6.12M 0s
3550K .......... .......... .......... .......... .......... 83% 4.76M 0s
3600K .......... .......... .......... .......... .......... 84% 8.12M 0s
3650K .......... .......... .......... .......... .......... 86% 7.05M 0s
3700K .......... .......... .......... .......... .......... 87% 6.16M 0s
3750K .......... .......... .......... .......... .......... 88% 4.32M 0s
3800K .......... .......... .......... .......... .......... 89% 6.25M 0s
3850K .......... .......... .......... .......... .......... 90% 5.37M 0s
3900K .......... .......... .......... .......... .......... 91% 6.99M 0s
3950K .......... .......... .......... .......... .......... 93% 7.07M 0s
4000K .......... .......... .......... .......... .......... 94% 6.12M 0s
4050K .......... .......... .......... .......... .......... 95% 6.63M 0s
4100K .......... .......... .......... .......... .......... 96% 5.65M 0s
4150K .......... .......... .......... .......... .......... 97% 7.70M 0s
4200K .......... .......... .......... .......... .......... 98% 3.04M 0s
4250K .......... .......... .......... .......... ...... 100% 4.95M=0.8s
2023-10-29 11:27:31 (5.31 MB/s) - '/tmp/image.tgz' saved [4399753/4399753]
grwkak
Re: Meteobridge offline
Post by grwkak »
There was a bug in the released application stack for RPI. It is fixed now, just reboot and be fine again.
